Topic: outlaw receiver 976 plus crown amp Q&A (Read 157 times) previous topic - next topic
i have 3 set of Crown XLi 800 for my fronts centers an surrounds all 98db sen. an a xls 1502 for my two 15in subs 92db sen.
their all connected to my outlaw audio 976 receivers xlr outs they are rated at 4volt min to 9volt maximum
my question is on the crown amps  should i have the Selectable input voltage at .755V or 1.4V
Re: outlaw receiver 976 plus crown amp Q&A
I'd say1.4V.   ...You'lll be able to use more of the volume control range.    With 9V out and 0.775V sensitivity you can't even use 10% of the volume-control range.   With 1.4V sensitivity you're still using less than 20% of the range.   And in most "home" situations you won't be anywhere near the limits of the Crown amplifiers.   ;)
I don't know what "minimum" means...   With the volume turned-down or quiet program material you'll get less signal.    With the volume control turned all the way down you'll get (almost) zero volts.
thanks im going try that
