Topic: Converter Error - SACD-R (DST-64) to MP3 320kbps (Read 174 times) previous topic - next topic
Hello, the issue is the failure about the conversion from SACD-R (DST-64) to MP3 320kbps.
Converter Status Report
1 out of 1 tracks converted with major problems.
Source: "C:\Users\mrfly\Downloads\America - Homecoming 1972 (2015 AF Remaster ISO)\Audio Fidelity - Homecoming.iso" / index: 18
  An error occurred while writing to file (The encoder has terminated prematurely with code -1 (0xFFFFFFFF); please re-check parameters) : "C:\Users\mrfly\Desktop\California Revisited.mp3"
  Additional information:
  Encoder stream format: 44100Hz / 6ch / 24bps
  Command line: "C:\Program Files (x86)\foobar2000\encoders\lame.exe" -S --noreplaygain -b 320 - "California Revisited.mp3"
  Working folder: C:\Users\mrfly\Desktop\
  Conversion failed: The encoder has terminated prematurely with code -1 (0xFFFFFFFF); please re-check parameters
Installed components
Core (2018-11-14 09:33:10 UTC)
    foobar2000 core 1.4.1
foo_ac3.dll (2010-01-11 01:48:40 UTC)
    AC3 decoder 0.9.4
foo_albumlist.dll (2018-11-14 09:32:28 UTC)
    Album List 4.6
foo_burninate.dll (2012-09-11 12:40:06 UTC)
    Audio CD Writer 3.0.3
foo_cad.dll (2013-01-14 11:41:10 UTC)
    CD Art Display 1.0.2
foo_cdda.dll (2018-11-14 09:32:30 UTC)
    CD Audio Decoder 3.0
foo_chacon.dll (2018-11-17 20:53:14 UTC)
    Chacon 3
foo_converter.dll (2018-11-14 09:32:34 UTC)
    Converter 1.5.3
foo_dsp_eq.dll (2018-11-14 09:32:22 UTC)
    Equalizer 1.2.1
foo_dsp_prvb.dll (2019-01-09 16:02:41 UTC)
    Programmable reverb DSP 1.3
foo_dsp_std.dll (2018-11-14 09:32:28 UTC)
    Standard DSP Array 1.3.2
foo_fileops.dll (2018-11-14 09:32:30 UTC)
    File Operations 2.3
foo_freedb2.dll (2018-11-14 09:32:36 UTC)
    Online Tagger 0.7
foo_input_ht.dll (2018-12-08 16:49:25 UTC)
    Highly Theoretical 2.0.50
foo_input_monkey.dll (2018-12-08 12:21:48 UTC)
    Monkey's Audio Decoder 2.1.9
foo_input_reverse.dll (2018-12-08 11:45:10 UTC)
    Reverse Player 1.0
foo_input_sacd.dll (2019-03-04 14:23:04 UTC)
    Super Audio CD Decoder 1.1.1
foo_input_std.dll (2018-11-14 09:32:56 UTC)
    FFmpeg Decoders 3.2.4
    Standard Input Array 1.0
foo_input_tak.dll (2018-12-08 12:21:58 UTC)
    TAK Decoder 0.4.8
foo_input_tta.dll (2018-12-23 18:42:22 UTC)
    TTA Audio Decoder 3.5
foo_jesus.dll (2010-09-23 01:34:06 UTC)
    Autosave & Autobackup 10
foo_keep_queue.dll (2010-11-12 03:28:46 UTC)
    Keep Queue 0.3.5
foo_masstag.dll (2009-09-18 00:31:36 UTC)
    Masstagger 1.8.4
foo_out_asio.dll (2019-03-10 09:08:26 UTC)
    ASIO support 2.1.2
foo_podcatcher.dll (2011-03-12 04:43:36 UTC)
    Podcatcher 0.2.5 (beta, Mar 12 2011)
foo_queuecontents.dll (2012-12-26 06:06:16 UTC)
    Queue Contents Editor 0.5.1
foo_quicksearch.dll (2012-10-29 16:44:48 UTC)
    Quick Search Toolbar 3.4
foo_rgscan.dll (2018-11-14 09:32:34 UTC)
    ReplayGain Scanner 2.3
foo_ui_columns.dll (2011-02-27 20:23:00 UTC)
    Columns UI 0.3.8.8
foo_ui_hacks.dll (2012-12-23 17:12:14 UTC)
    UI Hacks 2012-12-24
foo_ui_std.dll (2018-11-14 09:32:44 UTC)
    Default User Interface 0.9.5
foo_uie_library_tree.dll (2011-07-24 08:38:24 UTC)
    Library Tree 0.3.4.6.1
foo_uie_panel_splitter.dll (2009-12-09 14:46:12 UTC)
    Panel Stack Splitter 0.3.8.3(alpha)
foo_uie_vis_channel_spectrum.dll (2008-05-17 17:32:12 UTC)
    Channel Spectrum panel 0.17.2
foo_uie_wsh_panel_mod.dll (2010-09-09 07:35:08 UTC)
    WSH Panel Mod 1.3.7
foo_unpack.dll (2018-11-14 09:32:40 UTC)
    ZIP/GZIP/RAR Reader 1.8
foo_w7shell.dll (2012-02-05 10:20:52 UTC)
    Windows 7 integration 0.2.9.1
foo_wave_seekbar.dll (2013-01-18 01:18:37 UTC)
    Waveform seekbar 0.2.29
foo_winamp_ipc.dll (2012-12-26 17:17:04 UTC)
    Winamp IPC emulator 0.1.3
Re: Converter Error - SACD-R (DST-64) to MP3 320kbps
You are trying to encode 6-channel audio. LAME doesn't support 6 channels. You should downmix to stereo before encoding
Thank you for your reply, I tried this method:
1) Convert from SACD-R (DST-64) to FLAC compression level 5 (processing: downmix channels to stereo)
2) Convert the converted FLAC to MP3 320kbps
Maybe not the best way but idk.
Added processing: downmix channels to stereo directly to mp3 converter.
Thank you again.
