Topic: Hiding panel frames (Read 307 times) previous topic - next topic
Hiding panel frames
Quick question how do I got about hiding these I've looked and can't find any method?
Re: Hiding panel frames
If that's made in Default UI you can't change them as far as I know.
Columns UI can set the divider width manually. The Panel Stack Splitter component can also set them.
Alternatively you might be able to modify your Windows skin to draw those dividers as a dark color to make it less visible.
