Topic: How to access OneDrive files via web? (Read 472 times) previous topic - next topic
Team,
I've searched but not found an answer. I would like to access all the files on OneDrive from another PC via foobar.
I cannot download the files locally so I tried to add the https:// path of the root folder of my music in foobar but it was not able to discover (and play/stream) the content.
Is there any solution for it?
any plugin?
thank you for the help,
M
Re: How to access OneDrive files via web?
You need to get direct link to file first - https://solvemethod.com/onedrive-direct-link
Then you should install foo_input_ffmpeg, download ffmpeg and set foo_input_ffmpeg to play files over https
Then use File->Add location... to add file to playlist
thank you a lot!
maybe I'm doing something wrong but I'm not able to get it working.
I always get an error:
Unable to open item for playback (ffprobe failed):
"https://onedrive.live.com/download?cid=A2A0DDB076B45588&resid=A2A0DDB076B45588!411494&authkey=APOgMYtt4xZS6"
also your method works on a single file, but if I want to play all files in a folder?
Your link doesn't work even in browser.
I created link myself and it works https://onedrive.live.com/download?cid=6D16B30A6767734F&resid=6D16B30A6767734F%21114&authkey=AHXJUtx1SB4aUAs
Just discovered that for some file types you even don't need foo_input_ffmpeg. For example mp3 works even without foo_input_ffmpeg. But for FLAC you will need foo_input_ffmpeg.
ok, thank you. I think I missed some chars when I copied the link. Yours work.
But it does not browse the folders, correct? there is no way
