Topic: Variable speed. Restore the file order of the list. (Read 982 times) previous topic - next topic
1.
Sometimes listening to slow songs is about 1.5 times or 2 times faster.
2.
Sometimes you accidentally press to sort, press to name or evaluation, you want to change back to the original order.
3.
When dragging a folder to a list, the order is not the order of the folders
The order in which you want to set the files to be dragged and dropped to the list is "file name increment or decrement" "sort by folder order" "sort by file order in folder" "separate files of multiple subfolders separately".
4.
When you drag a file to the list, it is automatically placed on the last line.
This is a button that turns the feature on or off.
Is it possible to add these features? How long does it take to publish?
Re: Variable speed. Restore the file order of the list.
https://www.foobar2000.org/components/view/foo_dsp_effect
CTRL+Z or Main menu Edit->Undo
