Topic: How to make multiple metadata values appear seperately in lists? (Read 256 times) previous topic - next topic
When I split multiple metadata values for artist and composer foobar simply replaces the / with a comma.
But all the artists and composers still appear as a string in my overviews (see pictures).
This is especially annoying considering my naming scheme is already: Surname, Forename which makes the whole mess confusing as heck.
I would like the separate values to also appear separately in my overviews with the rest of that artist or composer's works.
How is this possible?
p.s. Is there also a way I can get Foobar to auto-split these values when it detects a certain symbol? And what symbol do you guys suggest I use for splitting values?
Hhhmmmm Croissants.....
Re: How to make multiple metadata values appear seperately in lists?
Hey there,
Have a play around with the $meta_sep() function.
Example: $meta_sep(artist,' + ') = "Artist 1 + Artist 2 + Artist 3"
See title formatting reference here.
I just use '+' myself but you could put any fancy character or unicode icon in there.
Cheers ;)
Forgive the absolute noob question, but where exactly am I supposed to enter this?
When I put it in the split field dialog nothing happens?
Put it wherever you are displaying artist (or composer) in those two screenshots above. Replace the %artist% part with $meta_sep(artist,' + ') - it will display artists the same but with a custom separator between each artist.
I cannot tell what particular element or component you are using in the screenshots, though...
I do not recognize the component either, and I'm only familiar with the default user interface where you can use this syntax to display each individual composer from a multi value field: %<composer>%
The many commas are indeed hard to read, and reason why I wouldn't use last-first name sorting. I think colored separators would go a long way to visually organize the list, and help distiguish comma, semicolon or ampersand as separator from one that is part of a proper name. The color can be only slightly different. On the default user interface it is not possible to use color in $meta_sep(), but we can insert some unique string and wrap the line with $replace() to change that to a color code.
$replace($meta_sep(composer,'C_X1, C_X0'),C_X1,<<,C_X0,>>)
or old style literal color
$replace($meta_sep(composer,'C_X1, C_X0'),C_X1,808080,C_X0,)
EDIT: Nvm j7n's solution worked perfectly. Thanks guys!
I was using facets BTW.
Thanks j7n, your solution worked perfectly!
Not sure whether you meant this or not, but the last-first name thing isn't a sorting method I use. I actually enter the names that way in the metadata.
I'm not sure how you use anything other than last-first name sorting with classical music?
Surely you'd want Johann Sebastian Bach to be sorted as B for Bach, not J for Johann?
Am I missing something?
