Try to crossfade and kill the gaps in tracks 2019-01-30 10:25:02 I"ll try to crossfade and kill the gaps with this configuration. Please tell me if it works or need some adjustment.Thank you.DSP chain:1. foo dsp crossfader2. Foo fadeinout3. Foo dsp continuator Last Edit: 2019-01-30 10:30:21 by Simon_ Thunder
Re: Try to crossfade and kill the gaps in tracks Reply #1 – 2019-01-30 12:34:35 A litle adjustment for flac files:Set in foo dsp crossfader value: Seeking - 30% or 25%
Re: Try to crossfade and kill the gaps in tracks Reply #2 – 2019-01-30 15:47:30 Adjust the fade in stepness to 0.09 in foo dsp continuator.
Re: Try to crossfade and kill the gaps in tracks Reply #3 – 2019-01-30 19:20:04 Quote from: Simon_ Thunder on 2019-01-30 10:25:02I"ll try to crossfade and kill the gaps with this configuration. Please tell me if it works or need some adjustment.Thank you.DSP chain:1. foo dsp crossfader - http://foobar2000.xrea.jp/up/files/up1128.7z2. Foo fadeinout -https://www.foobar2000.org/components/view/foo_dsp_fadeinout3. Foo dsp continuator - http://home.onego.ru/~vdx/foo_dsp_continuator_061_eng.7z
