foo_vis_simple_spectrum Reply #75 – 2007-07-17 21:03:17 I second (actually, twohundredfourtynine) that
foo_vis_simple_spectrum Reply #76 – 2007-08-01 05:58:19 Quote from: foosion on 2006-02-14 21:49:37foo_vis_manager is contained in the foobar2000 installer. You have to reinstall foobar2000 and explicitly select it.Hello foosion how are you? I tried following your advice and re-installed Foobar2000 0.9 but I did not see ANYWHERE the option to install foo_vis_manager. Is there some other way of obtaining this dll file?
foo_vis_simple_spectrum Reply #77 – 2007-08-01 09:40:52 It is not needed for foobar2000 0.9.x. On the other hand, the simple spectrum visualization is not available for foobar2000 0.9.x either.
foo_vis_simple_spectrum Reply #78 – 2010-09-14 18:01:01 Any chance to update this plugin for foobar 1.0 and columnsUI? Panel version. Last Edit: 2010-09-14 18:02:08 by radi0n
