Topic: foo_vis_simple_spectrum (Read 90828 times) previous topic - next topic
I think there is a bug in the panel plugin when resizing the columns ui sidebar. Just add the simple spectrum to the sidebar and then minimize the width. When the sidebar is about a few pixels wide the plugin will crash.[a href="index.php?act=findpost&pid=251318"][{POST_SNAPBACK}][/a]
Confirmed. I'll post a fixed version soon.
is there any chance of geting a panel version of VU meter (foo_vis_vu_meter) ?[a href="index.php?act=findpost&pid=251321"][{POST_SNAPBACK}][/a]
Well, it's on my personal wishlist already.
Hello,
Is it possible to remove the grid?
Cheers
Updated panel version for ui_extension SDK 5.0.0, download link remains the same.
Edit: Nevermind, got it working.
I have put the dll in my components dir and everything and I went to enable vis processing. Its all checked and all that good stuff. But nothing is showing up.
Any idea's why its not showing up?
because you didn't start it by using Visualization -> Simple spectrum in the Components menu, maybe?
Reply #32
Well I copied my playlist formatting and all to a new foobar config file and now it all works fine. Before I didn't have that menu at all.
foosion, don't you think you ought to change
wc.hbrBackground = 0;
to
wc.hbrBackground = (HBRUSH)(COLOR_BTNFACE+1);
I was looking through your code because I wanted to learn how to use your UIE helper and noticed that. I actually had some random occurences (by random, I mean I didn't bother figuring out what was the case) when the panel window was (pseudo) transperant.
By the way, thanks for your UIE helper. It really helps write a much more managable UIE panel.
Reply #34
foosion, don't you think you ought to change[a href="index.php?act=findpost&pid=260414"][{POST_SNAPBACK}][/a]
I think I ought to change quite a lot in this component occasionally, but thanks for the hint.
Glad that you like the UIE helper.
Reply #35
how show(enable) foo_uie_simple_spectrum.dll in foo_ui_columns ? :-/
WBR,  Vitaliy I. Bogdanets
Foobar2000 - The way it's meant to be played
Reply #36
how show(enable) foo_uie_simple_spectrum.dll in foo_ui_columns ? :-/[a href="index.php?act=findpost&pid=260505"][{POST_SNAPBACK}][/a]
Do you have the latest version of foo_ui_columns? If so, rightclick on the toolbar or on a header in the sidebar and choose "Visualizations/Simple spectrum".
Reply #37
[a href="index.php?act=findpost&pid=260520"][{POST_SNAPBACK}][/a]
hmmm...
if foo_ui_columns 1.2.b3+foo_uie_simple_spectrum 1.5 work good, why in 1.6 version it not work ?    :-/
PS: this menu "Visualizations/Simple spectrum" is just gone    :-/
2foosion: you don't know, when appear foo_uie_bacon(or g-force), foo_uie_equalizer , foo_uie_id3tag_changer ?
Reply #38
The UI extension API in foo_ui_columns changed from 0.1.2b3 to 0.1.2b4, foo_uie_simple_spectrum 0.1.6 requires foo_ui_columns 0.1.2b4 or newer.
How would I know that? As for a panel version of the Winamp vis wrapper, I think it has been said that it's impossible.
Reply #39
it's not help
http://www.hydrogenaudio.org/forums/index....ndpost&p=260883
[a href="index.php?act=findpost&pid=260664"][{POST_SNAPBACK}][/a]
i's very bad    but somebody create something better
Reply #40
[a href="index.php?act=findpost&pid=251446"][{POST_SNAPBACK}][/a]
Any update on this matter?
Reply #41
Any update on this matter? [a href="index.php?act=findpost&pid=272399"][{POST_SNAPBACK}][/a]
No, it's rather low on my wishlist.
Reply #43
this is a really nice plugin, thanks much.
i have been interested for a long time in getting a simple spectrum with a log-scale y axis. this seems like it should be really simple, and it would have the beautiful consequence that the spectrum could be superimposed on a musical scale. in fact, one could ideally note use chromatic scale halfsteps as the tick marks.
thanks very much for your great work.
stephen
Reply #44
A logarithmic frequency scale is not very high on my to-do list currently. I think some older version had one, but it was removed when I restructured the code. Before you ask: no, it's not trivial to add it back right now.
Reply #45
[a href="index.php?act=findpost&pid=308158"][{POST_SNAPBACK}][/a]
Ah, that's too bad. If you ever *do* add it back, or if the older version is lying about somewhere handy, I'd be much obliged. In the meantime, thanks much, anyway. It's a nice piece of software.
stephen
Reply #46
I have a problem with this plugin : I was fighting for a long time against some low level noises in my speakers, when foobar's playing. Like a kind of 2-3 seconds wobulation from low to high to low frequencies, appearing ramdomly in time. I recorded a sound played by foobar with cooledit and spectrumed it. I saw the sound I was actually playing, and a parasite noise represented by many diagonal lines. Foobar was the only player to generate such noises, so I decided to deactivate each component one by one. It's a fact that when i close the 'simple spectrum panel', the noise disappears (foo_uie_simple_spectrum-0.1.6). Does anyone have ever noticed that???  is it posible that a vis. plugin affects the sound of foobar?
Anyway, I'm happy to have find the solution, but also disappointed cause i like this nice spectrum...
Emu 1212m, PIV 2Ghz, ATI9550, WinXp, Debian Etch
Reply #47
Hate to resurrect old threads, but I was playing with foo_uie_simple_spectrum and I was wondering how trivial (or not) it would be, when running it with all channels (2 in my case) to have them back to back (i.e. flip the bottom display top to bottom)
thoughts?
Reply #48
i seem to have a problem with simple spectrum... problem is it isn't showing up
Reply #49
i need foo_vis_manager
please help !
