Topic: Dual Playlist view? (Read 200 times) previous topic - next topic
Dual Playlist view?
Hello there,
I'm having trouble with the way Foobar (win7 64bit) behaves in relation to playlists.
My goal here is to create a layout with two independent playlists shown at any one time. I can create two instances of the playlist view with tabs, meaning I can work with multiple playlists in parallel, but these two windows always mirror one another - when I select playlist 1 on the left section, the right section cannot display any other playlist without influencing the left section in response.
Is there any known solution to this? I'm trying to have a general playlist on the left with album/genre collections, and another separate playlist on the right to burn to CD to make DJ compilations. I need to be able to view both simultaneously. On a slightly unrelated note, has anyone successfully burned CDs that carry track names so that CDJs can read them?
Cheers
BIG DRIVER
Re: Dual Playlist view?
If you download additional playlist viewer components they should work independently as I recall. At the very least you can pin one of them so it only shows the contents of one specific playlist.
Try something like SimPlaylist or EsPlaylist/ELPlaylist. One of them probably supports what you want.
What about running two instances of fb2k? If you run the installer a second time and install fb2k as a portable version, you can run the "installed" fb2k and "portable" fb2k at the same time.
ESPlaylist has this option: right-click and select Playlists -> Follow XXX playlist. The XXX playlist must be selected at the time, but after that you can switch the other viewer and this one will stay where it was.
