Right options for downsampling with SoX Resampler
To @lvqcl and others who may want to chip in:
Discussions on quality apart, I, upon using the FB2K SoX Resampler plugin for downsampling 24/96 FLAC files to 16/44.1 WAV, was wondering whether I'm doing it the right way or not, as follows:
As I'm obviously not executing the resampler under the CLI, but on FB2K, I guess the only choice I have for reducing the bit depth from 24 to 16 bits, is by checking the "Output bit depth" on FB2K's converter's "Choose output file format dialogue box', right?
And...
At the same dialogue box, I should leave "Dither" unchecked for the sake of leaving up to Sox Resampler's discretion how to appropriately deal with it, correct?
Finally, those two questions are just that: question from someone whom is obviously doing that for the first time and wants to make sure they're doing the right thing - no implication whatsoever on whether dithering (which has been discussed ad nauseam here and elsewhere) is a good thing or not.
Thank you.
