Topic: foo_cuefixer (works like old foo_cuefilter but open source) (Read 2482 times) previous topic - next topic
Hi! I created open plugin "foo_cuefixer" that removes referenced files on add, enqueue operations.
for example you has SomeAlbum directory:
- somealbum.cue (which has song timings)
- somealbum.flac
if you add this directory to foobar you will get:
- somealbum_song1
- somealbum_song2
- somealbum_song3
- somealbum.flac file
So this plugins remove that uselsess duplicates.
Source code on github
Release version
P.S. Dont forget to remove "*.CUE" from preferencess->shell integration->exclude file types
Re: foo_cuefixer (works like old foo_cuefilter but open source)
Interesting project, thank you.
thank you!
Thank you, good man! This plugin has to be included in foobar2000 standard package!
It helps not only with CUE but APL files too.
It's universal and open source.
so cool.
Let's see if it has no bugs. :)
nice job!
Nice, thank you.
Wow, much appreciated!
Great component! Thanks for your work :)
This will work with .APE, .WV and .WAV?.
Edit:
I'm using portable mode on foobar2000 and doesn't work. There's duplicate files on my Playlist.
Thank you for your effort.
Unfortunately, it doesn't filter CUE for non-existing files in folder, namely CUE pointing to .wav files.
Thanks for your work RevenantX !
This works like a charm and solved the painful issue I had.
