Topic: Must UI element" Properties" ignore Always preload complete info up to N tracks? (Read 194 times) previous topic - next topic
I ask because currently (fb2k 1.4.2 beta 1, but IIRC behavior always was the same) UI element "Selection Properties" seems to ignore "Always preload complete info up to N tracks" setting.
For example. I have "unsyncedlyrics" added to spam fields in LargeFieldsConfig.txt. unsyncedlyrics is added to Standard fields in advanced settings. Advanced->Display->Properties dialog->Always preload complete info up to N tracks is set to 100. So In Context menu->Properties i can see content of unsyncedlyrics field. But UI element "Selection Properties" refuses to follow this setting (Always preload complete info up to N tracks is set to 100) and shows only dot instead of content of unsyncedlyrics field. Is it supposed to be this way?
Re: Must UI element" Properties" ignore Always preload complete info up to N tracks?
Selection properties is meant to show cached info only, it never accesses your files. This is by design.
