Topic: Cannot access partitions/drives using Linux Foobar2000 (Read 262 times) previous topic - next topic
Sorry if this has been asked before but I have an issue with the Linux port of Foobar2000. I have a dual-boot setup (Linux and Window 10) and Foobar2000 isn't showing any mounted drives where I keep all my playlists and music files. If I try to load a playlist it only shows the 'C' drive where Windows is and a 'Z' drive where Linux is.
I have tried to find an option to unlock/show other partitions which are mounted but there can't find anything.  Is there a work around for this issue?  All other Linux players can 'see' my other partitions so it doesn't appear to be a 'mounted' issue. I am quite new to Linux, so this is a bit of a head-scratcher for me.
Thanks in advance for any help...
Re: Cannot access partitions/drives using Linux Foobar2000
There is no official Linux port of foobar so perhaps explain your setup in more detail. Are you using WINE to run it on Linux?
Thanks for replying. I installed it using the terminal with snap. It was an online guide..
http://ubuntuhandbook.org/index.php/2018/02/install-foobar2000-snap-ubuntu-16-04/
Wine doesn't appear to be installed. Ive tried searching for it but the name doesn't come up.
Foobar2000 runs ok, but it's just accessing my music drives that I have an issue with.
Then you are better off asking the maintainer/community of said project. Also, it uses WINE under the hood, based on the beginning of the article you linked.
Ok many thanks
If you use a snap, you can't access your entire filesystem. You'll have to find another way, or somehow grant extensive permissions to that snap.
