Topic: Reset the library (Read 135 times) previous topic - next topic
Reset the library
Hello everyone, I wanted to know if Foobar stores the library data somewhere and since there are things that do not square me I wanted to know if it is possible to reset all the data in memory of the library and to reload it from the beginning.
Thank you
Re: Reset the library
Hey there,
What does not square with you exactly?
The library data is whatever folders you add to Library menu > Configure > Music Folders. You can either remove all folders to reset (not really necessary), or just right-click a folder > Rescan Now to scan for changes. Alternatively, (hold shift key) Library menu > Rescan Folders to do the same.
Cheers
