Topic: Can't playback this MP4 package file (Read 216 times) previous topic - next topic
Hi all, I grabbed this file from a web TS stream (offered by Vimeo), but can't play it with Foobar2000 directly.
It says "invalid or missing mvhd data"
I can either
- play it via any video player or even browser;
- easily convert it losslessly using FFMPEG to standard M4a or similar and play it just fine
But what I'm curious is if it's possible to play it directly with Foobar2000, i.e. if there is anyway to make fb2k to be able to decode this kind of package (iso5 (iso6/mp41)?), because AFAIK Foobar2000 can already decode most of common packages (like mp4, m4a, mka, mkv...) except this one.
File (just a 1.4 MB dialog): https://files.catbox.moe/ig482e.mp4
Also in attachment.
MediaInfo:
General
Complete name                            : D:\a.mp4
Format                                   : MPEG-4
Format profile                           : Base Media
Codec ID                                 : iso5 (iso6/mp41)
File size                                : 1.36 MiB
Duration                                 : 1 min 22 s
Overall bit rate                         : 139 kb/s
Writing application                      : Lavf58.19.102
Audio
Format                                   : AAC LC
Format/Info                              : Advanced Audio Codec Low Complexity
Codec ID                                 : mp4a-40-2
Bit rate                                 : 137 kb/s
Channel(s)                               : 2 channels
Channel layout                           : L R
Sampling rate                            : 48.0 kHz
Frame rate                               : 46.875 FPS (1024 SPF)
Compression mode                         : Lossy
Stream size                              : 1.34 MiB (99%)
Default                                  : Yes
Alternate group                          : 1
Re: Can't playback this MP4 package file
By "package" I mean "container", sorry about that!
This file has duration fields filled with nulls instead of valid duration. Though it's otherwise readable and the missing data is easily recalculated.
Fixed for the next update, thanks for reporting.
Addressed in 1.4.2 beta 1.
