Topic: Open With action wipes current playlist (Read 258 times) previous topic - next topic
In Windows, when you open a media file in fb2k via file association, the currently open playlist is wiped and the opened file is added. This is an ancient issue, I finally decided to report it. Personally, the last thing I want to have happen is one of my carefully curated playlists to get wiped. Fortunately there's an 'undo' action, but it's still upsetting whenever it happens.
In Settings, I found that under Shell Integration, I can toggle 'Always send new files to playlist: <name>'. But this has the same problem - everytime a file is opened, the previous contents of that playlist are wiped. I'm not sure, but wouldn't it be more reasonable to append instead? Or maybe even have it exist in a temporary void, where it's being played but doesn't appear on any playlist (like what happens if you remove an entry while it's being played).
Re: Open With action wipes current playlist
You need to enable Set "Enqueue" as the default action
| TAK pMax | QAAC ~ 192 kbps |
While you can simply follow Shinsekai's instructions also, why not just make up a playlist name only for files you open via file association but do not care to append to an existing playlist, and use that for the "Always send new files to.." method.  That keeps you from having to remove appended entries from "permanent" playlists as the content of the "temporary" list then gets wiped every time as you have noticed.
Setting enqueue as the default action doesn't help as it still clears the playlist if you use File -> Open.
Same with the default playlist setting.
Tested on newly downloaded foobar 1.4.2 beta 1 (Extracted portable into a clean place)
But I doubt anyone actually uses file -> open to add files (I don't) so it can stay as is.
