Topic: WAV to APE via BAT file ()How to do it?) (Read 2242 times) previous topic - next topic
I'm trying to find info that'll allow me to create Monkey's Audio files from WAV files via a BAT file, but can't find any info here about it, or on the web. Does anybody know how to do it?
Re: WAV to APE via BAT file ()How to do it?)
You compress with a bat file the same way you convert on command prompt. How complex a file you need depends on what you are trying to achieve. Here's a sample script to convert dropped files to APEs into the same directory where the WAV files are in.
@echo off
:loop
mac.exe "%~1" "%~d1%~p1%~n1.ape" -c2000
shift
if not ."%~1"==."" goto loop
Created a BAT file with the info you provided, and it worked. I was able to modify it so that the command prompt box stayed around until I closed it by adding two lines at the end:
@echo off
:loop
mac.exe "%~1" "%~d1%~p1%~n1.ape" -c3000
shift
:end
pause
I found, though, that if I added the -v command, it converted without verifying at all. I ended up having to create a seperate BAT file just to do that.
@echo off
:loop
mac.exe "%~d1%~p1%~n1.ape" -v
shift
:end
pause
Is there a way to combine the two into one BAT file that creates, then verifies an ape file? If not, I'm perfectly happy with using the two seperate BAT file to do everything.
You can add the verification line 'mac.exe "%~d1%~p1%~n1.ape" -v' after the compression line.
Ended up with this:
@echo off
:loop
shift
:end
pause
And I got this result:
--- Monkey's Audio Console Front End (v 4.40) (c) Matthew T. Ashland ---
Compressing (high)...
Progress: 100.0% (0.0 seconds remaining, 5.2 seconds total)
Success...
Verifying...
Progress: 100.0% (0.0 seconds remaining, 6.3 seconds total)
Success...
Press any key to continue . . .
Finally, it works! Thanks for the assistance, guys.
