Topic: Verified accurate in dbpoweramp but not in EAC? (Read 287 times) previous topic - next topic
This is the exact same disc, brand new giving different results in dbpoweramp and EAC. There is only version of this CD.
dbpoweramp log:
dBpoweramp Release 16.4 Digital Audio Extraction Log from Tuesday, November 27, 2018 16:07
Drive & Settings
Ripping with drive 'D:   [HL-DT-ST - DVDRAM GUE0N    ]',  Drive offset: 102,  Overread Lead-in/out: No
AccurateRip: Active,  Using C2: No,  Cache: 1024 KB,  FUA Cache Invalidate: No
Pass 1 Drive Speed: Max,  Pass 2 Drive Speed: Max
Ultra::  Vary Drive Speed: No,  Min Passes: 2,  Max Passes: 4,  Finish After Clean Passes: 2
Bad Sector Re-rip::  Drive Speed: Max,  Maximum Re-reads: 34
Encoder: FLAC -compression-level-5 -verify
Extraction Log
Track 1:  Ripped LBA 0 to 14965 (3:19) in 0:25. Filename: C:\Himalia\Artur Schnabel\Beethoven; Piano Works, Vol. 1\01 - Piano Sonata No. 1 in F minor, Op. 2-1; Allegro._
  AccurateRip: Accurate (confidence 8)     [Pass 1]
  CRC32: 50309B21     AccurateRip CRC: 7D141C64     [DiscID: 012-001c3f5d-010e519d-9b0fa00c-1]
  AccurateRip Verified Confidence 8 [CRCv2 7d141c64], Using Pressing Offset -6
  AccurateRip Verified Confidence 5 [CRCv1 5f37901e], Using Pressing Offset -6
  AccurateRip Verified Confidence 3 [CRCv2 7cf4d94], Using Pressing Offset -92
  AccurateRip Verified Confidence 3 [CRCv1 d37514ef], Using Pressing Offset -92
Track 2:  Ripped LBA 14965 to 42142 (6:02) in 0:28. Filename: C:\Himalia\Artur Schnabel\Beethoven; Piano Works, Vol. 1\02 - Piano Sonata No. 1 in F minor, Op. 2-1; Adagio._
  AccurateRip: Accurate (confidence 9)     [Pass 1]
  CRC32: B7CDCC85     AccurateRip CRC: 0DB75833     [DiscID: 012-001c3f5d-010e519d-9b0fa00c-2]
  AccurateRip Verified Confidence 9 [CRCv2 db75833], Using Pressing Offset -6
  AccurateRip Verified Confidence 5 [CRCv1 753392eb], Using Pressing Offset -6
  AccurateRip Verified Confidence 3 [CRCv2 1367a824], Using Pressing Offset -92
  AccurateRip Verified Confidence 3 [CRCv1 9056c194], Using Pressing Offset -92
Track 3:  Ripped LBA 42142 to 57542 (3:25) in 0:14. Filename: C:\Himalia\Artur Schnabel\Beethoven; Piano Works, Vol. 1\03 - Piano Sonata No. 1 in F minor, Op. 2-1; Menuetto._
  CRC32: 5BE6D2A3     AccurateRip CRC: 6A1E7532     [DiscID: 012-001c3f5d-010e519d-9b0fa00c-3]
  AccurateRip Verified Confidence 9 [CRCv2 6a1e7532], Using Pressing Offset -6
  AccurateRip Verified Confidence 5 [CRCv1 19370e1a], Using Pressing Offset -6
  AccurateRip Verified Confidence 3 [CRCv2 10686a90], Using Pressing Offset -92
  AccurateRip Verified Confidence 3 [CRCv1 a8485ba9], Using Pressing Offset -92
Track 4:  Ripped LBA 57542 to 79167 (4:48) in 0:19. Filename: C:\Himalia\Artur Schnabel\Beethoven; Piano Works, Vol. 1\04 - Piano Sonata No. 1 in F minor, Op. 2-1; Prestissimo._
  CRC32: 8DE060E8     AccurateRip CRC: 931775E8     [DiscID: 012-001c3f5d-010e519d-9b0fa00c-4]
  AccurateRip Verified Confidence 9 [CRCv2 931775e8], Using Pressing Offset -6
  AccurateRip Verified Confidence 5 [CRCv1 3d4af5ac], Using Pressing Offset -6
  AccurateRip Verified Confidence 3 [CRCv2 5de446f], Using Pressing Offset -92
  AccurateRip Verified Confidence 3 [CRCv1 906a8cbf], Using Pressing Offset -92
Track 5:  Ripped LBA 79167 to 108540 (6:31) in 0:24. Filename: C:\Himalia\Artur Schnabel\Beethoven; Piano Works, Vol. 1\05 - Piano Sonata No. 2 in A major, Op. 2-2; Allegro vivace._
  CRC32: 3EAF01C1     AccurateRip CRC: 48B3212B     [DiscID: 012-001c3f5d-010e519d-9b0fa00c-5]
  AccurateRip Verified Confidence 9 [CRCv2 48b3212b], Using Pressing Offset -6
  AccurateRip Verified Confidence 5 [CRCv1 1717a93e], Using Pressing Offset -6
  AccurateRip Verified Confidence 3 [CRCv2 79ce7808], Using Pressing Offset -92
  AccurateRip Verified Confidence 3 [CRCv1 37289ebc], Using Pressing Offset -92
Track 6:  Ripped LBA 108540 to 141690 (7:22) in 0:24. Filename: C:\Himalia\Artur Schnabel\Beethoven; Piano Works, Vol. 1\06 - Piano Sonata No. 2 in A major, Op. 2-2; Largo appassionato._
  CRC32: 29B95190     AccurateRip CRC: 6A66C86D     [DiscID: 012-001c3f5d-010e519d-9b0fa00c-6]
  AccurateRip Verified Confidence 9 [CRCv2 6a66c86d], Using Pressing Offset -6
  AccurateRip Verified Confidence 5 [CRCv1 9fd98b1a], Using Pressing Offset -6
  AccurateRip Verified Confidence 3 [CRCv2 d90105c5], Using Pressing Offset -92
  AccurateRip Verified Confidence 3 [CRCv1 dcb36159], Using Pressing Offset -92
Track 7:  Ripped LBA 141690 to 156822 (3:21) in 0:10. Filename: C:\Himalia\Artur Schnabel\Beethoven; Piano Works, Vol. 1\07 - Piano Sonata No. 2 in A major, Op. 2-2; Scherzo._
  CRC32: C93793AA     AccurateRip CRC: 9BD5E683     [DiscID: 012-001c3f5d-010e519d-9b0fa00c-7]
  AccurateRip Verified Confidence 9 [CRCv2 9bd5e683], Using Pressing Offset -6
  AccurateRip Verified Confidence 5 [CRCv1 7ea63d23], Using Pressing Offset -6
  AccurateRip Verified Confidence 3 [CRCv2 13b44ca2], Using Pressing Offset -92
  AccurateRip Verified Confidence 3 [CRCv1 9286d65], Using Pressing Offset -92
Track 8:  Ripped LBA 156822 to 183027 (5:49) in 0:17. Filename: C:\Himalia\Artur Schnabel\Beethoven; Piano Works, Vol. 1\08 - Piano Sonata No. 2 in A major, Op. 2-2; Rondo; Grazioso._
  CRC32: 95A515B0     AccurateRip CRC: 8872F61E     [DiscID: 012-001c3f5d-010e519d-9b0fa00c-8]
  AccurateRip Verified Confidence 8 [CRCv2 8872f61e], Using Pressing Offset -6
  AccurateRip Verified Confidence 5 [CRCv1 34e71f9e], Using Pressing Offset -6
  AccurateRip Verified Confidence 3 [CRCv2 3c83ccf0], Using Pressing Offset -92
  AccurateRip Verified Confidence 3 [CRCv1 c202faff], Using Pressing Offset -92
Track 9:  Ripped LBA 183027 to 228257 (10:03) in 0:28. Filename: C:\Himalia\Artur Schnabel\Beethoven; Piano Works, Vol. 1\09 - Piano Sonata No. 3 in C major, Op. 2-3; Allegro con brio._
  CRC32: 960ACAFE     AccurateRip CRC: 61886362     [DiscID: 012-001c3f5d-010e519d-9b0fa00c-9]
  AccurateRip Verified Confidence 8 [CRCv2 61886362], Using Pressing Offset -6
  AccurateRip Verified Confidence 5 [CRCv1 e7d15efc], Using Pressing Offset -6
  AccurateRip Verified Confidence 3 [CRCv2 4ca24289], Using Pressing Offset -92
  AccurateRip Verified Confidence 3 [CRCv1 cb0f9417], Using Pressing Offset -92
Track 10:  Ripped LBA 228257 to 263130 (7:44) in 0:20. Filename: C:\Himalia\Artur Schnabel\Beethoven; Piano Works, Vol. 1\10 - Piano Sonata No. 3 in C major, Op. 2-3; Adagio._
  CRC32: 3DEFD43A     AccurateRip CRC: F940851D     [DiscID: 012-001c3f5d-010e519d-9b0fa00c-10]
  AccurateRip Verified Confidence 8 [CRCv2 f940851d], Using Pressing Offset -6
  AccurateRip Verified Confidence 5 [CRCv1 8617c67c], Using Pressing Offset -6
  AccurateRip Verified Confidence 3 [CRCv2 fd32d892], Using Pressing Offset -92
  AccurateRip Verified Confidence 3 [CRCv1 5eef9fef], Using Pressing Offset -92
Track 11:  Ripped LBA 263130 to 275947 (2:50) in 0:07. Filename: C:\Himalia\Artur Schnabel\Beethoven; Piano Works, Vol. 1\11 - Piano Sonata No. 3 in C major, Op. 2-3; Scherzo._
  CRC32: 4E346361     AccurateRip CRC: EA9D8259     [DiscID: 012-001c3f5d-010e519d-9b0fa00c-11]
  AccurateRip Verified Confidence 8 [CRCv2 ea9d8259], Using Pressing Offset -6
  AccurateRip Verified Confidence 5 [CRCv1 cc5ca7ad], Using Pressing Offset -6
  AccurateRip Verified Confidence 3 [CRCv2 535ff1a7], Using Pressing Offset -92
  AccurateRip Verified Confidence 3 [CRCv1 34449aac], Using Pressing Offset -92
Track 12:  Ripped LBA 275947 to 300000 (5:20) in 0:54. Filename: C:\Himalia\Artur Schnabel\Beethoven; Piano Works, Vol. 1\12 - Piano Sonata No. 3 in C major, Op. 2-3; Allegro assai._
  AccurateRip: Inaccurate (confidence 8)   Secure  [Pass 1 & 2, Ultra 1 to 2]
  CRC32: 013C3DE7     AccurateRip CRC: CE16126B (CRCv2)     [DiscID: 012-001c3f5d-010e519d-9b0fa00c-12]
12 Tracks Ripped: 11 Accurate, 1 Secure
EAC:
Exact Audio Copy V1.3 from 2. September 2016
EAC extraction logfile from 27. November 2018, 17:58
Artur Schnabel / Piano Works Vol. 1
Used drive  : HL-DT-STDVDRAM GT33N   Adapter: 1  ID: 0
Read mode               : Secure
Utilize accurate stream : Yes
Defeat audio cache      : Yes
Make use of C2 pointers : No
Read offset correction                      : 103
Overread into Lead-In and Lead-Out          : No
Delete leading and trailing silent blocks   : No
Null samples used in CRC calculations       : Yes
Used interface                              : Native Win32 interface for Win NT & 2000
Gap handling                                : Appended to previous track
Used output format              : User Defined Encoder
Selected bitrate                : 128 kBit/s
Quality                         : High
Add ID3 tag                     : No
Command line compressor         : C:\Program Files (x86)\Exact Audio Copy\Flac\flac.exe
Additional command line options : -8 -V -T "ARTIST=%artist%" -T "TITLE=%title%" -T "ALBUM=%albumtitle%" -T "DATE=%year%" -T "TRACKNUMBER=%tracknr%" -T "TOTALTRACKS=%numtracks%" -T "GENRE=%genre%" -T "ALBUMARTIST=%albumartist%" -T "ALBUM ARTIST=%albumartist%" -T "COMMENT=EAC Secure Mode, Test & Copy, AccurateRip, FLAC -8" %source%
TOC of the extracted CD
     Track |   Start  |  Length  | Start sector | End sector
        1  |  0:00.00 |  3:19.40 |         0    |    14964
        2  |  3:19.40 |  6:02.27 |     14965    |    42141
        3  |  9:21.67 |  3:25.25 |     42142    |    57541
        4  | 12:47.17 |  4:48.25 |     57542    |    79166
        5  | 17:35.42 |  6:31.48 |     79167    |   108539
        6  | 24:07.15 |  7:22.00 |    108540    |   141689
        7  | 31:29.15 |  3:21.57 |    141690    |   156821
        8  | 34:50.72 |  5:49.30 |    156822    |   183026
        9  | 40:40.27 | 10:03.05 |    183027    |   228256
       10  | 50:43.32 |  7:44.73 |    228257    |   263129
       11  | 58:28.30 |  2:50.67 |    263130    |   275946
       12  | 61:19.22 |  5:20.53 |    275947    |   299999
Track  1
     Filename C:\Aitne\01 - Piano Sonata No. 1 in f, Op. 2 No. 1 I Allegro.wav
     Pre-gap length  0:00:02.00
     Peak level 67.9 %
     Extraction speed 2.2 X
     Track quality 99.9 %
     Test CRC 50309B21
     Copy CRC 50309B21
     Cannot be verified as accurate (confidence 8)  [4D20C4CF], AccurateRip returned [7D141C64]  (AR v2)
     Copy OK
Track  2
     Filename C:\Aitne\02 - Piano Sonata No. 1 in f, Op. 2 No. 1 II Adagio.wav
     Pre-gap length  0:00:01.08
     Peak level 56.1 %
     Extraction speed 3.0 X
     Track quality 100.0 %
     Test CRC B7CDCC85
     Copy CRC B7CDCC85
     Cannot be verified as accurate (confidence 9)  [173017C1], AccurateRip returned [0DB75833]  (AR v2)
     Copy OK
Track  3
     Filename C:\Aitne\03 - Piano Sonata No. 1 in f, Op.02 No. 1  III Menuetto and Trio (Allegretto).wav
     Peak level 73.0 %
     Extraction speed 3.1 X
     Test CRC 5BE6D2A3
     Copy CRC 5BE6D2A3
     Cannot be verified as accurate (confidence 9)  [78B91638], AccurateRip returned [6A1E7532]  (AR v2)
     Copy OK
Track  4
     Filename C:\Aitne\04 - Piano Sonata No. 1 in f, Op.02 No. 1 IV Prestissimo.wav
     Pre-gap length  0:00:01.25
     Peak level 77.1 %
     Extraction speed 3.4 X
     Test CRC 8DE060E8
     Copy CRC 8DE060E8
     Cannot be verified as accurate (confidence 9)  [91CD8131], AccurateRip returned [931775E8]  (AR v2)
     Copy OK
Track  5
     Filename C:\Aitne\05 - Piano Sonata No. 2 in A, Op.02 No. 2 I Allegro vivace.wav
     Pre-gap length  0:00:07.15
     Peak level 81.1 %
     Extraction speed 3.8 X
     Test CRC 3EAF01C1
     Copy CRC 3EAF01C1
     Cannot be verified as accurate (confidence 9)  [4DF536F1], AccurateRip returned [48B3212B]  (AR v2)
     Copy OK
Track  6
     Filename C:\Aitne\06 - Piano Sonata No. 2 in A, Op.02 No. 2 II Largo appassionato.wav
     Pre-gap length  0:00:01.73
     Peak level 88.5 %
     Extraction speed 4.2 X
     Test CRC 29B95190
     Copy CRC 29B95190
     Cannot be verified as accurate (confidence 9)  [67ED279D], AccurateRip returned [6A66C86D]  (AR v2)
     Copy OK
Track  7
     Filename C:\Aitne\07 - Piano Sonata No. 2 in A, Op.02 No. 2 III Scherzo and Trio (Allegretto).wav
     Peak level 72.1 %
     Extraction speed 4.0 X
     Test CRC C93793AA
     Copy CRC C93793AA
     Cannot be verified as accurate (confidence 9)  [59D1AE8F], AccurateRip returned [9BD5E683]  (AR v2)
     Copy OK
Track  8
     Filename C:\Aitne\08 - Piano Sonata No. 2 in A, Op.02 No. 2 IV Rondo (Grazioso).wav
     Peak level 65.4 %
     Extraction speed 4.6 X
     Test CRC 95A515B0
     Copy CRC 95A515B0
     Cannot be verified as accurate (confidence 8)  [09A27EE5], AccurateRip returned [8872F61E]  (AR v2)
     Copy OK
Track  9
     Filename C:\Aitne\09 - Piano Sonata No. 3 in C, Op.02 No. 3 I Allegro con brio.wav
     Pre-gap length  0:00:07.05
     Peak level 99.9 %
     Extraction speed 5.1 X
     Test CRC 960ACAFE
     Copy CRC 960ACAFE
     Cannot be verified as accurate (confidence 8)  [5F5D9CE5], AccurateRip returned [61886362]  (AR v2)
     Copy OK
Track 10
     Filename C:\Aitne\10 - Piano Sonata No. 3 in C, Op.02 No. 3 II Adagio.wav
     Peak level 86.6 %
     Extraction speed 5.3 X
     Test CRC 3DEFD43A
     Copy CRC 3DEFD43A
     Cannot be verified as accurate (confidence 8)  [0C924E62], AccurateRip returned [F940851D]  (AR v2)
     Copy OK
Track 11
     Filename C:\Aitne\11 - Piano Sonata No. 3 in C, Op.02 No. 3 III Scherzo and Trio - Allegro.wav
     Pre-gap length  0:00:00.01
     Peak level 80.1 %
     Extraction speed 4.8 X
     Test CRC 4E346361
     Copy CRC 4E346361
     Cannot be verified as accurate (confidence 8)  [A0B6010C], AccurateRip returned [EA9D8259]  (AR v2)
     Copy OK
Track 12
     Filename C:\Aitne\12 - Piano Sonata No. 3 in C, Op.02 No. 3 IV Allegro assai.wav
     Peak level 77.6 %
     Extraction speed 4.9 X
     Test CRC 013C3DE7
     Copy CRC 013C3DE7
     Cannot be verified as accurate (confidence 8)  [CE16126B], AccurateRip returned [9DCAEEC0]  (AR v2)
     Copy OK
No tracks could be verified as accurate
You may have a different pressing from the one(s) in the database
No errors occurred
End of status report
---- CUETools DB Plugin V2.1.6
[CTDB TOCID: HUg17t81nRbTeiKEWh5nW8ddyLk-] found
Submit result: already submitted
Track | CTDB Status
  1   | (16/16) Accurately ripped
  2   | (16/16) Accurately ripped
  3   | (16/16) Accurately ripped
  4   | (16/16) Accurately ripped
  5   | (16/16) Accurately ripped
  6   | (16/16) Accurately ripped
  7   | (16/16) Accurately ripped
  8   | (16/16) Accurately ripped
  9   | (16/16) Accurately ripped
 10   | (16/16) Accurately ripped
 11   | (16/16) Accurately ripped
 12   | ( 4/16) Accurately ripped, or (12/16) differs in 2948 samples @02:05:26-02:05:27,02:07:67,02:09:31-02:09:32,02:09:50,02:10:71-02:10:72,02:11:15-02:11:16,02:11:53-02:11:54,02:11:72,02:12:35
If you are sure that your rip contains errors, you can use CUETools to repair it.
==== Log checksum 26869F795B7C57BF5E56307F761B469341700AA557BFAAE9C90CFAAC0F3454F5 ====
Re: Verified accurate in dbpoweramp but not in EAC?
Cannot be verified as accurate (confidence 8) [4D20C4CF], AccurateRip returned [7D141C64]  (AR v2))
EAC cannot check AccurateRip across pressings/offsets. The AccurateRip plugin in EAC can only verify results for your specific pressing.
dBpoweramp can check AccurateRip across pressings/offsets and found matches at Pressing Offset -6 and Pressing Offset -92.
http://wiki.hydrogenaud.io/index.php?title=AccurateRip#Pressings
korth
I've ripped quite a few discs in EAC, surely when something comes up below with an AR of 20 it has to have done across a wide variety of offsets?
EAC extraction logfile from 4. September 2018, 20:27
Rudolf Serkin / Beethoven Piano Concertos (Kubelik) (CD1)
Used drive  : hp      DVDRW  DA8AESH   Adapter: 1  ID: 0
Read mode               : Secure
Read offset correction                      : 6
Quality                         : High
Add ID3 tag                     : No
        1  |  0:00.00 | 17:27.05 |         0    |    78529
        2  | 17:27.05 | 10:36.25 |     78530    |   126254
        3  | 28:03.30 |  9:24.00 |    126255    |   168554
        4  | 37:27.30 | 14:02.70 |    168555    |   231774
        5  | 51:30.25 |  8:10.57 |    231775    |   268581
        6  | 59:41.07 |  6:11.40 |    268582    |   296446
Track  1
     Filename C:\Himalia\01 - Piano concerto No.1 in C major, op.15 - I. Allegro con brio.wav
     Peak level 41.9 %
     Extraction speed 3.5 X
     Test CRC 8016942F
     Copy CRC 8016942F
     Accurately ripped (confidence 20)  [62DCB2C5]  (AR v2)
     Copy OK
Track  2
     Filename C:\Himalia\02 - Piano concerto No.1 in C major, op.15 - II. Largo.wav
     Peak level 28.8 %
     Extraction speed 4.4 X
     Test CRC 387FB2B3
     Copy CRC 387FB2B3
     Accurately ripped (confidence 20)  [1C3ED92D]  (AR v2)
     Copy OK
Track  3
     Filename C:\Himalia\03 - Piano concerto No.1 in C major, op.15 - III. Rondo- Allegro.wav
     Peak level 43.8 %
     Test CRC B017E179
     Copy CRC B017E179
     Accurately ripped (confidence 20)  [044FE8B4]  (AR v2)
     Copy OK
Track  4
     Filename C:\Himalia\04 - Piano Concerto No.2 in B major, op.19 - I. Allegro con brio.wav
     Pre-gap length  0:00:08.58
     Peak level 46.0 %
     Extraction speed 5.2 X
     Test CRC 64B2ACD0
     Copy CRC 64B2ACD0
     Accurately ripped (confidence 20)  [557B91EF]  (AR v2)
     Copy OK
Track  5
     Filename C:\Himalia\05 - Piano Concerto No.2 in B major, op.19 - II. Adagio.wav
     Pre-gap length  0:00:06.53
     Peak level 34.2 %
     Extraction speed 5.8 X
     Test CRC 18009F1D
     Copy CRC 18009F1D
     Accurately ripped (confidence 20)  [8DBDC158]  (AR v2)
     Copy OK
Track  6
     Filename C:\Himalia\06 - Piano Concerto No.2 in B major, op.19 - III. Rondo- Allegro molto.wav
     Peak level 44.5 %
     Test CRC FFCF66FD
     Copy CRC FFCF66FD
     Accurately ripped (confidence 19)  [AF9C3CE0]  (AR v2)
     Copy OK
All tracks accurately ripped
No errors occurred
[CTDB TOCID: 8DUg7djfJpNehb5lvauk78MU2cc-] found
Submit result: 8DUg7djfJpNehb5lvauk78MU2cc- has been confirmed
Track | CTDB Status
  1   | (21/21) Accurately ripped
  2   | (21/21) Accurately ripped
  3   | (21/21) Accurately ripped
  4   | (21/21) Accurately ripped
  5   | (21/21) Accurately ripped
  6   | (20/21) Accurately ripped
==== Log checksum 60EEA63FC1DBB26C06D3E703D5C42C9B861DBE39D90B087AD4850096A05E55F4 ====
Each pressing will produce different checksums because the data is in a different position. ARv1 checksums and ARv2 checksums are different and treated as different pressings in the database.  All checksums for all pressings are stored together in the database for each track.
The AccurateRip plugin in EAC is checksum matching. It calculates ARv1 and ARv2 checksums for each track then looks for matches in the database. For
Track  1
the plugin found no matches but other checksums existed so it reported that the track couldn't be verified as accurate along with the first non-matching checksum [7D141C64], the confidence level (8) and AR version (v2) of that checksum plus the (AR v2) checksum it calculated [4D20C4CF] for that track from your rip. You'll note that the non-matching checksum was the same v2 checksum and confidence level for Pressing Offset -6 in Track 1 of the dBpoweramp log.
Track 1:
korth
Alright, that makes sense thank you.
