random playback with artist and song repeat protection? 2018-11-19 18:01:05 I'm searching for a plugin with random playback and with configurable artist and song repeat protection. That's something beyond foobar2000 shuffle capabilities.
Re: random playback with artist and song repeat protection? Reply #1 – 2018-11-20 00:53:35 You want shuffle, which has repeat protection, not random, which doesn't.
Re: random playback with artist and song repeat protection? Reply #2 – 2018-11-21 07:14:01 Shuffle tracks is the most close option. But it tends to play same artist more than once in 1 hour. My collection is currently 1373 songs and no artist has more than 32 songs. And about song protection, my collection has several instances of "Hey Joe" and "Season of the Witch". How could shuffle tracks understand that they are basically same song, only with different performer?
Re: random playback with artist and song repeat protection? Reply #3 – 2018-11-21 08:24:38 Quote from: takora on 2018-11-21 07:14:01How could shuffle tracks understand that they are basically same song, only with different performer?is your question, "why doesn't my audio player have artificial intelligence?" You can use Shuffle.You can use playback statistics and filter only songs that have never been played (%play_count% MISSING):https://www.foobar2000.org/components/view/foo_playcountYou can use random pools and control how often an album or artist is played:https://www.foobar2000.org/components/view/foo_random_pools
Re: random playback with artist and song repeat protection? Reply #4 – 2018-11-21 13:16:50 Basically I was talking about 'configurability' of artist and song repeat protection. Maybe some external file where I can define that I consider Frank Zappa and "Mothers of Invention" the same artist. Or that I consider "Season of the Witch" by Donovan and by Vanilla Fudge the same song. Or that shuffle should not repeat artist or album or song title in 60 or 120 or 180 or some other amount of minutes. Where I can define that "The Trip" by Kim Fowley and "Let's Take a Trip" by Godrey & Friends are the same song. That's not AI I guess... And the radio stations are using some similar rules. Let's call it Shuffle (radio)?I have heard about the Random Pools plugin. If this can be done with Random Pools, I should give it a try.
Re: random playback with artist and song repeat protection? Reply #5 – 2018-11-22 20:54:32 The developer of foo_random_pools said it can't be done with his plugin... Sad. All radio stations got this kind of repeat protection. It's probably not very hard to implement.
Re: random playback with artist and song repeat protection? Reply #6 – 2018-11-23 03:36:36 You realize there are actually human beings at the majority of stations selecting and playing the music? Robot stations have FAR more than 1400 songs, so one doesn't hear repeat.For the amount of time spent on automating a small # of songs, you could have already organized them into a playlist manually, or spent the time finding new music.
Re: random playback with artist and song repeat protection? Reply #7 – 2018-11-23 04:22:04 Actually, I guess the software major radio stations are using got repeat protection, so why not foobar2000? can't run radio station without it... it would be lame...
Re: random playback with artist and song repeat protection? Reply #8 – 2018-11-23 05:08:28 to mjm716you're some fanboy? you're happy if things not working? what's your problem actually?
Re: random playback with artist and song repeat protection? Reply #9 – 2018-11-24 04:12:58 There is no repeat mode that is designed purely to make sure there are whole days of nonstop music between replaying any given artist. Perhaps you could be the first to craft such a random playlist generator?
Re: random playback with artist and song repeat protection? Reply #10 – 2019-01-18 15:07:05 Foo Random Pools by StrigUI configuration - random playback with artist and song repeat protection.You just need download F2K random pools component and configuration file (attached below)1. Unzip the archive to: foo_random_pools.dll to components folder and foo_random_pools.cfg to configuration folder.2. Create the playlist and name it Auto DJ and add you library some folder3.Set playback order to default.4. Go to main window: File - Random pools - Auto DJ (with rating or without rating).5. Random pools with this configuration picks random track from your library and stopped on last track.
Re: random playback with artist and song repeat protection? Reply #11 – 2019-01-18 15:25:23 Did you read the entire thread? Foo_random_pools has been mentioned before and has been said to not work according to OP's wishes.
Re: random playback with artist and song repeat protection? Reply #12 – 2019-01-18 16:00:39 Quote from: Simon_ Thunder on 2019-01-18 15:07:05You just need download F2K random pools component and configuration file (attached below)^ Also not a great idea to include a component (someone elses hard work) in an attachment this way when there are perfectly valid working links - should always get software from the authentic source. (You could have just posted the config file. ) Last Edit: 2019-01-18 16:03:22 by anamorphic
Re: random playback with artist and song repeat protection? Reply #13 – 2019-01-19 16:58:04 Quote from: jazzthieve on 2019-01-18 15:25:23Did you read the entire thread? Foo_random_pools has been mentioned before and has been said to not work according to OP's wishes.I know this. They suggest him random pools plugin.Did you ever try StigUi config?According StigUI config there is no repeat of tracks were played. Last Edit: 2019-01-19 17:07:25 by Simon_ Thunder
Re: random playback with artist and song repeat protection? Reply #14 – 2019-01-19 17:01:37 Quote from: anamorphic on 2019-01-18 16:00:39Quote from: Simon_ Thunder on 2019-01-18 15:07:05You just need download F2K random pools component and configuration file (attached below)^ Also not a great idea to include a component (someone elses hard work) in an attachment this way when there are perfectly valid working links - should always get software from the authentic source. (You could have just posted the config file. ) I just attached both files for newbie and lazy people. I give a big thanks to author of random pools component. And big thanks to StriGUI for configuration file.Thats all. Last Edit: 2019-01-19 17:21:43 by Simon_ Thunder
