Topic: foo_dsp_bs2b recompiled (Read 5126 times) previous topic - next topic
Here's Bauer stereophonic-to-binaural DSP plugin recompiled with the latest SDK.
Changes:
- removed clipping of signals that exceed ±1.0 (i.e. 0 dBFS);
- removed code that is not needed for foobar2000 component;
- added signal extrapolation to reduce a possibility of clicks during track change;
- recompiled with latest SDK (2018-10-11). Works with foobar2000 1.4.x; users of 1.3.x need to download and install MSVC redist (here).
Original component: https://hydrogenaud.io/index.php/topic,38291.0.html
Re: foo_dsp_bs2b recompiled
Changes:
Thank you.
Can you please recompile:
1. foo.dsp.continuator for f2k 0.8.3 and for f2k v1
2. foo.dsp.crossfader
3. foo.binpack
Nope. Too much work, no fun.
Also, sources for foo_dsp_crossfader and foo_binpack aren't even available, so what do you think I should recompile?
You don't understand what you are talking about, do you?
I am understand, You talking about SRC.
