foo_dsp_bs2b recompiled 2018-11-05 21:46:54 Here's Bauer stereophonic-to-binaural DSP plugin recompiled with the latest SDK.Changes:- removed clipping of signals that exceed ±1.0 (i.e. 0 dBFS);- removed code that is not needed for foobar2000 component;- added signal extrapolation to reduce a possibility of clicks during track change;- recompiled with latest SDK (2018-10-11). Works with foobar2000 1.4.x; users of 1.3.x need to download and install MSVC redist (here).Original component: https://hydrogenaud.io/index.php/topic,38291.0.html
Re: foo_dsp_bs2b recompiled Reply #1 – 2020-08-21 10:22:39 Quote from: lvqcl on 2018-11-05 21:46:54Here's Bauer stereophonic-to-binaural DSP plugin recompiled with the latest SDK.Changes:- removed clipping of signals that exceed ±1.0 (i.e. 0 dBFS);- removed code that is not needed for foobar2000 component;- added signal extrapolation to reduce a possibility of clicks during track change;- recompiled with latest SDK (2018-10-11). Works with foobar2000 1.4.x; users of 1.3.x need to download and install MSVC redist (here).Original component: https://hydrogenaud.io/index.php/topic,38291.0.htmlThank you.Can you please recompile:1. foo.dsp.continuator for f2k 0.8.3 and for f2k v12. foo.dsp.crossfader3. foo.binpack
Re: foo_dsp_bs2b recompiled Reply #2 – 2020-08-21 17:40:03 Nope. Too much work, no fun.Also, sources for foo_dsp_crossfader and foo_binpack aren't even available, so what do you think I should recompile?You don't understand what you are talking about, do you?
Re: foo_dsp_bs2b recompiled Reply #3 – 2020-08-22 04:13:14 Quote from: lvqcl on 2020-08-21 17:40:03Nope. Too much work, no fun.Also, sources for foo_dsp_crossfader and foo_binpack aren't even available, so what do you think I should recompile?You don't understand what you are talking about, do you?I am understand, You talking about SRC.
