Topic: is there a way to monitor the output of an audio player? (Read 423 times) previous topic - next topic
Hi
first i'm a novice and just for knowledge and test purpose
according my ears , several audio players do sound different on the same hardware
i tried foobar + wasapi (event) "no dsp " , musicbee wasapi event , aimp wasapi event and under sierra audirvana plus 3
at the beginning i wanted to use Voxengo SPAN via vst but audirvana doesn't let using vst , again i'm a novice , but
i have tried for many times the same album in flac 44.1 ripped with eac and played with foobar 1.4 wasapi event and audirvana plus 3 under sierra and high sierra
i'm talking about my ears , for my ears the same album played under w10 and foobar sounds clean ,cold and with more "treble" , audirvana again for my ears sound more deep
so is there a way to monitor the audio player output?
do sombody tried it?
thanks
sorry for my poor english
Re: is there a way to monitor the output of an audio player?
You can use virtual sound card and some audio editor to record output from player. For windows there are free Virtual audio cable and free Audacity.
hi
sadly i don't how can i do with audirvana
under windows it does install a driver
have you tried to monitor audio players output?
thanks
in Windows there's WASAPI loopback device, just record from it. no special software needed.
you can use Audacity to record.
Keep calm and opusenc --bitrate 128
hi
but i can not play foobar+wasapi event and record with audacity with wasapi loopback
thanks
For Mac there exist Jack and Soundflower
AFAIK, when you use kernel mode driver (WASAPI Exclusive, native ASIO or WDM/KS) as output device in Foobar you are (normally) not allowed to access the device simultaenously by some other software if you go through DAC --> instead, if you use S/PDIF output you be able to capture (using S/PDIF loop cable or 2nd HW device) the output from there to some recording software for comparison (I would use some multitrack recording software (BandLab Sonar is free https://www.bandlab.com/products/cakewalk ),  sync the recorded tracks , compare two recordings at once by inverting the phase of the other track (silence is 1:1)).
