Need LAME 3.96.1 in 64 Bit version for windows 2018-11-01 13:40:07 Is possible to compile lame 3.96.1 in a 64bit executable for windows using the source from sourceforge?https://sourceforge.net/projects/lame/files/lame/3.96.1/Someone has tried in the past?
Re: Need LAME 3.96.1 in 64 Bit version for windows Reply #1 – 2018-11-01 13:51:08 Should work but why 3.96.1 and not the current 3.100? I really don't get this obsession with "old" versions.
Re: Need LAME 3.96.1 in 64 Bit version for windows Reply #2 – 2018-11-01 14:49:29 Because 3.96.1 version is the best for making V5 V6 vbr quality and cleanest files, with major version i can't reach such "quality" for that "low" bitrate (110~130).Someone is skilled with mingw64? How can i compile?I have a mingw32 set-up to compile 32bit, but i can't understand how to use the 64bit version for compile lame...I need 64bit because i use, also, xrecode 3 and the 32bit seems not work (produce only distortion noise).Do you want a sample to hear? Last Edit: 2018-11-01 14:51:54 by bruraschi
Re: Need LAME 3.96.1 in 64 Bit version for windows Reply #3 – 2018-11-01 15:09:35 Here, i catch some songs in 120~130 range, plus two songs that need more (encoded in abr mode 160kbps with tuned ath parameters) [Moderator Edit: Link Removed per TOS#9 - Clips were longer than 30 seconds]With upper lame versions, or fhg (from CoolEdit to CS6) at the same bitrate the quality is much lower. Last Edit: 2018-11-01 16:06:54 by korth
Re: Need LAME 3.96.1 in 64 Bit version for windows Reply #4 – 2018-11-01 17:06:17 Do you just need the lame.exe? I'll see if I can compile one for you over the weekend.
Re: Need LAME 3.96.1 in 64 Bit version for windows Reply #5 – 2018-11-01 17:24:33 Quote from: john33 on 2018-11-01 17:06:17Do you just need the lame.exe? I'll see if I can compile one for you over the weekend.Yes only lame.exe
Re: Need LAME 3.96.1 in 64 Bit version for windows Reply #6 – 2018-11-01 18:19:41 OK. I'll see what I can do.
Re: Need LAME 3.96.1 in 64 Bit version for windows Reply #7 – 2018-11-01 18:22:49 I just checked an old drive and have a zip of 3.96.1 that I would've taken from Rarewares. But it's obviously not a 64bit compile. I can always link it up if someone wanted it, but again, original 32bit compile.
Re: Need LAME 3.96.1 in 64 Bit version for windows Reply #8 – 2018-11-01 18:23:17 If you only need lame.exe then your problem is not related to its bitness.
Re: Need LAME 3.96.1 in 64 Bit version for windows Reply #9 – 2018-11-01 19:00:41 Rarewares has a link to a modified version that takes its arguments from a text file (see the readme):http://www.rarewares.org/files/mp3/lameexe3.96.1_MOD.zipThat version of lame is 15 years old though, and there were improvements afterwards so I probably wouldn't recommend it even if you managed to find some file where it works better.
Re: Need LAME 3.96.1 in 64 Bit version for windows Reply #10 – 2018-11-02 09:16:37 > Because 3.96.1 version is the best for making V5 V6 vbr quality and cleanest files, with major version i can't reach such "quality" for that "low" bitrate (110~130).Maybe it's worth reporting as a bug, then? Newer versions aren't supposed to become less efficient.
Re: Need LAME 3.96.1 in 64 Bit version for windows Reply #11 – 2018-11-02 14:06:56 Quote from: bruraschi on 2018-11-01 14:49:29Because 3.96.1 version is the best for making V5 V6 vbr quality and cleanest files, with major version i can't reach such "quality" for that "low" bitrate (110~130). That borders hitsTOS 8 territory, doesn't it? Or is it so old we shouldn't even bother?
Re: Need LAME 3.96.1 in 64 Bit version for windows Reply #12 – 2018-11-02 14:56:50 You can try 3.100 with --vbr-old to mimmcik 3.96 :lame -V5 --vbr-old sample-song.wav Last Edit: 2018-11-02 15:01:10 by shadowking
Re: Need LAME 3.96.1 in 64 Bit version for windows Reply #13 – 2018-11-02 15:20:11 When i remember right version 3.96 was really bad on many samples no matter what switches. 3.97 and 3.98 had many enhancements.The test corpus of guruboolez was of good help back then.Asking for 3.96 14 years later because of cleaner files must be a joke. Last Edit: 2018-11-02 15:37:48 by Wombat
Re: Need LAME 3.96.1 in 64 Bit version for windows Reply #14 – 2018-11-02 15:51:24 Quote from: Wombat on 2018-11-02 15:20:11Asking for 3.96 14 years later because of cleaner files must be a joke. Those were just my thoughts.
Re: Need LAME 3.96.1 in 64 Bit version for windows Reply #15 – 2018-11-02 17:01:46 Here we go: lame-3.96.1-x64.exeBriefly checked, but I think it's OK.
Re: Need LAME 3.96.1 in 64 Bit version for windows Reply #16 – 2018-11-02 19:28:13 Quote from: includemeout on 2018-11-02 15:51:24Quote from: Wombat on 2018-11-02 15:20:11Asking for 3.96 14 years later because of cleaner files must be a joke. Those were just my thoughts.It's not a joke, as long as I could I used the existing 32bit version. I understand that it is strange but on many low bitrate encodings, this version generates clean audio without artifacts. I'm sorry that the link with the sample has been moderated.Quote from: john33 on 2018-11-02 17:01:46Here we go: lame-3.96.1-x64.exeBriefly checked, but I think it's OK.Let me try it You are my savior!
Re: Need LAME 3.96.1 in 64 Bit version for windows Reply #17 – 2018-11-02 19:42:13 WORKS with every my programs !!!Many Many Thx!!!!!
Re: Need LAME 3.96.1 in 64 Bit version for windows Reply #18 – 2018-11-02 21:43:43 You're very welcome.
Re: Need LAME 3.96.1 in 64 Bit version for windows Reply #19 – 2018-12-29 16:54:54 Quote from: john33 on 2018-11-01 17:06:17Do you just need the lame.exe? I'll see if I can compile one for you over the weekend.hi @john33 might i have the dll (64bit and 32bit) ?i gave a look at rarewares , but i can't find 3.96.1 and 3.99.5 (both 64bit and 32bit)i'm looking for the same reason low variable rate and low cbr i'm looking for both , but i'm worried to get some virus for windowsthanks john33 ps before xmass , i wanted buy a daw so i download 4 trial audio programs , all updated and all come with lame 3.99.5 , even the last goldwave come with 3.99.5 , don't know why they prefer and old version
Re: Need LAME 3.96.1 in 64 Bit version for windows Reply #20 – 2018-12-29 17:08:17 OK, I'm away from home until the new year, I'll have a look after that. Please feel free to remind me if I appear to have forgotten!! Happy New Year.
Re: Need LAME 3.96.1 in 64 Bit version for windows Reply #21 – 2018-12-29 17:54:27 Quote from: john33 on 2018-12-29 17:08:17OK, I'm away from home until the new year, I'll have a look after that. Please feel free to remind me if I appear to have forgotten!! Happy New Year.thanks JohnHappy New Year to you John!
Re: Need LAME 3.96.1 in 64 Bit version for windows Reply #22 – 2019-06-03 07:27:03 Quote from: john33 on 2018-12-29 17:08:17OK, I'm away from home until the new year, I'll have a look after that. Please feel free to remind me if I appear to have forgotten!! Happy New Year.Hi @john33 i know it's late , i lost this topicat i have found 3.99.5 and is 3.96.1 lame-3.96.1-x64.rar ?http://www.rarewares.org/files/mp3/many software don't use the last lame 3.100 , for example the last reaper release i guess it uses 3.99.5.2.5thanks John
Re: Need LAME 3.96.1 in 64 Bit version for windows Reply #23 – 2019-06-03 07:53:11 I'll see what I can do for you.
Re: Need LAME 3.96.1 in 64 Bit version for windows Reply #24 – 2019-06-03 10:23:28 OK, these include the x64 executable and the dll. They are untested Intel compiles, so if you have a problem with them, please let me know.www.rarewares.org/files/mp3/lame-3.96.1-x64.rarandwww.rarewares.org/files/mp3/lame-3.99.5-x64.rar
