Topic: Minor Media Library UI Glitch (Read 442 times) previous topic - next topic
Stretching the UI Element horizontally causes minor glitches on the Syntax Help and the three dot menu buttons.
http://prntscr.com/l2zdwu
Re: Minor Media Library UI Glitch
Resolved in 1.4.1-beta.
Not here. I can still reproduce the glitch with 1.4.1 beta 1.
I couldn't replicate the issue even with 1.4. Peter could but not with 1.4.1. I think more info is needed how to trigger it.
The glitch is not always reproducible. It has to do with the speed of horizontally stretching..
Yes if only you stretch fast enough. although on 1.4.1-Beta.1 I'm not able to reproduce.
Right now I'm faced with another problem, the Tab labels text is a bit mispositioned.
if it helps these are my system settings:
Resolution: 4K (3820x2160)
Screen Diagonal: 15.6"
Scale: 250%
Windows 10, 1809
Fixed for the next update (1.4.1 beta 2). Thanks for reporting.
I can confirm, that the "three dots" repaint glitch is fixed in 1.4.1 beta 2, Thanks.
