Eventually I ran into a problem. I use some text files to share layout settings between jscript panels and panel stack splitter. I have a script which deletes a specific file when triggered, using the FileSystemObject DeleteFile method. It's a very simple script and it always worked with JScript Panel, but since migrating to Spider Monkey Panel the delete action is denied because the file is in use by foobar2000. I cannot even delete the file manually.
Could you provide the script (or it's relevant parts)?
Sure, as I said it's a pretty simple one. The panel is resized via PSS (panel stack splitter) and this triggers either a delete or a create file action. function on_size(){
switch (window.Height){
case 0:
if (fso.FileExists(SettingsPath + "PlaylistVisible")) fso.DeleteFile(SettingsPath + "PlaylistVisible");
RefreshPSS();
break;
case 1:
if (!fso.FileExists(SettingsPath + "PlaylistVisible")) fso.CreateTextFile(SettingsPath + "PlaylistVisible");
RefreshPSS();
break;
case 2:
RefreshPSS();
break;
Here's also the relevant code from another script, included in the preprocessor:var fso = new ActiveXObject("Scripting.FileSystemObject");
var SettingsPath = fb.ProfilePath + "settings\\";
function RefreshPSS() {
var Refresh_sys = window.GetProperty("Refresh_sys",true);
if (Refresh_sys < true) {
if (fb.IsPlaying || fb.IsPaused) {
fb.RunMainMenuCommand("View/Show status bar");
} else {
} else {
fb.RunMainMenuCommand("Playback/Play or Pause");
} else {
fb.RunMainMenuCommand("Playback/Play");
fb.RunMainMenuCommand("Playback/Stop");
The script seems to work for a few times right after foobar2000 start up, but eventually something happens which blocks the file, and I can't figure out what it could even be.
