Topic: Spider Monkey Panel (foo_spider_monkey_panel) (Read 106629 times) previous topic - next topic
Re: Spider Monkey Panel (foo_spider_monkey_panel)
Reply #600
I feel that you are talking past each other =)
So, I'll try to sum up all the things that @snotlicker said.
@regor , as it was mentioned above, in quite a few programming languages (and even in RegExp and windows command line) `\` character is used as an escape character or to form a control character. For example, `\n` is a control character for a new line, `\"` - escape the quote character.
Values that can be seen in property dialog have all the escape chars and control chars parsed.
So, in JS (and SMP) it will work like this:
window.SetProperty("escape_1", "\"");
console.log(window.GetProperty("escape_1"));  // Logged and displayed in Property dialog as `"`
window.SetProperty("escape_2", "\\");
console.log(window.GetProperty("escape_2"));  // Logged and displayed as `\`
window.SetProperty("path_1", "path\\to\\file.ext");
console.log(window.GetProperty("path_1")); // Logged and displayed as `path\to\file.ext`
window.SetProperty("path_2", "path/to/file.ext");
console.log(window.GetProperty("path_2")); // Logged and displayed as `path/to/file.ext`
window.SetProperty("control_1", "line_1\nline_2");
console.log(window.GetProperty("control_1"));
// Logged as:
// `line_1
// line_2`
// displayed as:
// `line_1line_2`
Thus, path strings in JS code should be either like this `path/to/file.ext` or like this `path\\to\\file.ext` .
Was a bug on my installation. New foobar profile worked right, I reinstalled everything and now works as expected. Have no idea what was going on.. since same lines of code behaved differently on different profiles.
Btw, I have one more doubt. I'm trying to create a playlist manager, like the autoplaylist list on samples but for standard playlists.
Right now I got it like this: There is a monitored folder, the UI loads all files within that folder (playlists), I can open them and they are loaded within foobar, update the file (i.e. save foobar playlist to binded file), rebind playlist and rename (renaming playlist on manager, renames the file itself and the playlist on foobar). All that is working. I only have a problem, I can delete the files using this function from helpers .
let app = new ActiveXObject('Shell.Application');
function _recycleFile(file) {
if (_isFile(file)) {
app.NameSpace(10).MoveHere(file);
But restoring the file becomes a problem. I can not find a way to move files from the bin to the original folder.  I use the Move method with this, something like this
let fso = new ActiveXObject('Scripting.FileSystemObject');
let recyclePath = "c:\\$RECYCLE.BIN\\" + app.NameSpace(10) + "\\" + file.FILENAME;
let restorePath = file.PATH;
fso.MoveFile(recyclePath , restorePath );
But files are never moved from the bin. I have tried with that recyclePath which does indeed work on explorer, but not using the move function. So as far as I understand, the path should be right since it works on explorer (?)
"c:\$RECYCLE.BIN\" points to the physical folder, and  "c:\$RECYCLE.BIN\" + app.NameSpace(10) to the virtual one containing all files from any HDD
Reply #601
I've tried looking through the documentation but I'm not getting any wiser so I thought I'd ask here.
I want to make a button that switches between shuffle track and default playback that works like how the play/pause button in the sample "playback buttons", anyone have any suggestions on how to make it work?
			if (plman.PlaybackOrder === 4){
fb.RunMainMenuCommand("Playback/Order/Default");
} else {
fb.RunMainMenuCommand("Playback/Order/Shuffle (tracks)");
That code worked to switch, thanks a lot.
I have to ask for more help though, sadly. I want to swap icon based on which order is active, how do I add that?
Reply #602
Well, you can use the plman.PlaybackOrder property to write a conditional statement for that, too, much in the same way as above. To keep it simple, if you are using actual images:
function on_paint(gr){
let img_path;
img_path = //path to the default icon image
} else {
img_path = //path to the shuffle icon image
let img = gdi.Image(img_path)
gr.GdiDrawBitmap(img.CreateRawBitmap(), dstX, dstY, dstW, dstH, srcX, srcY, srcW, srcH)
If you are using font icon characters the principle is the same.
I'm late
Reply #603
let img_path;
} else {
I think I'm too dumb for this, the current thing I use is this:
buttons.buttons.shuffle = new _button(2, 2, 32, 32, {normal : 'buttons\\Menu.png'}, (x, y) => { if (plman.PlaybackOrder === 4){ fb.RunMainMenuCommand("Playback/Order/Default"); } else { fb.RunMainMenuCommand("Playback/Order/Shuffle (tracks)"); } }, 'Shuffle');
Maybe I should just look for another skin that has this function and see how they did it because I can't figure this out. When I add the function I get image is null.
Reply #604
I see, you're editing marc's script! I thought you were writing your own code. That makes it a little more complicated because you need to look at the code of at least three different scripts to understand where and how to edit (playback buttons, helpers and panel I think). I don't use it and I'm not familiar with it, but in that line of code you posted, the button image is likely passed by the fith argument of the _button() function, which is an object:
So first of all you need to have the required image files in the buttons folder and than you could try replacing "menu" with a variable and assign that variable the appropriate value with the conditional statement I suggested in the previous post. You could write the conditional statement in the on_playback_order_changed() callback, for example. But really, I would need to have a better look at the scripts before suggesting anything.
I'm late
Reply #605
So you recommend I start from scratch instead?
Reply #606
I encourage anyone to write their own rather than hacking other people's scripts, unless they are fairly simple and straightforward standalone scripts. But good coders usually don't have standalone scripts, but more complex systems which are hard to edit without breaking something. Nevertheless, meanwhile I had a look at the scripts and something easy you could try is editing the line of code you posted as follows:
buttons.buttons.shuffle = new _button(2, 2, 32, 32, {normal : plman.PlaybackOrder === 4 ? 'buttons\\deafult.png' : 'buttons\\shuffle.png'}, (x, y) => { if (plman.PlaybackOrder === 4){ fb.RunMainMenuCommand("Playback/Order/Default"); } else { fb.RunMainMenuCommand("Playback/Order/Shuffle (tracks)"); } }, 'Shuffle');
Than add the following:
function on_playback_order_changed(){
buttons.update();
window.Repaint();
Of course this works if you have a "shuffle.png" and "default.png" file in the buttons folder.
I'm late
Reply #607
P.S.
While we are at it, you can use the ternary operator ('?' and ':') for the conditional statement of the command as well:
buttons.buttons.shuffle = new _button(2, 2, 32, 32, {normal : plman.PlaybackOrder === 4 ? 'buttons\\deafult.png' : 'buttons\\shuffle.png'}, (x, y) => plman.PlaybackOrder === 4 ? fb.RunMainMenuCommand("Playback/Order/Default") : fb.RunMainMenuCommand("Playback/Order/Shuffle (tracks)"), 'shuffle');
I'm late
Reply #608
P.S.
Works just the way I want it, thanks for your help :)
This is how I made it look, top right corner, greyed out when not enabled:
Reply #609
@Qwertiest
I've added some info. on issue 'ActiveXObject error when dealing with exotic filename encodings #54' on github. Hope this helped. If you need further info. please let me know.
Reply #610
Check if the path ends with .cue or use title formatting for embedded cuesheets %__cue_embedded% equals yes
If cue is external (i.e. not embedded), you may also try checking FbMetadbHandle.SubSong, it seems to be above zero only when it's a multi-track file.
Not necessarily. If you are using mtags with one file for each track, the subsong index is always 1.
Reply #611
How do you save a playlist to a path? I found nothing about that on the documentation only SavePlaylist() and using a main menu command I can not add the path.
Any help there would be appreciated too.
Reply #612
marc2k3 just aded that functionality btw.
Well just found the problem is the (physical) name gets changed by the SO after sending a file to the Recycle Bin, so "a.txt" is changed to "$K4354A.txt" or things like that, while the explorer displays the original (virtual) name. I have now to list all files on the bin and identify the one I deleted, will report if that works for restoring purposes.
Reply #613
Also, is there some method to create a simple yes/no popupBox without using HTML?
popupBox(window_id, prompt, okString, cancelString)  -> return true/false
Obviously InputBox() could be used along try/catch to emulate that functionality but it looks weird (since the window expects a text input).
X
Reply #614
You can get original filename by using the following code:
let dir = app.NameSpace(10);
let items = dir.Items();
// Regretfully, `dir.Items()` is not enumerable, so it must be traversed manually
for (let i = 0; i < items.Count; ++i) {
   console.log(items.Item(i).Name); // original name
   console.log(items.Item(i).Path); // full path in recycle bin
Not sure I want to add this method, but I will put it on the maybe list in case I change my mind (it does happen =)).
Not currently, but I'll see if it can be done.
@Qwertiest
Thanks, I'll take a look.
Reply #615
Simple popups are already possible and have been in my samples for years.
let WshShell = new ActiveXObject('WScript.Shell');
let popup = {
ok : 0,
yes_no : 4,
yes : 6,
no : 7,
stop : 16,
question : 32,
info : 64
let prompt = ...
let caption = ...
if (WshShell.Popup(prompt, 0, caption, popup.question + popup.yes_no) == popup.yes) {
//do something
edit: see here for other button combos I've not included
https://www.devguru.com/content/technologies/wsh/wshshell-popup.html
Reply #616
Yep I did the same and finally got it working.  Thanks :) For reference, if anyone needs to do the same (it's just an improvement to marc's helpers):
const fso = new ActiveXObject('Scripting.FileSystemObject');
const app = new ActiveXObject('Shell.Application');
function _isFile(file) {
return _.isString(file) ? fso.FileExists(file) : false;
function _isFolder(folder) {
return _.isString(folder) ? fso.FolderExists(folder) : false;
function _createFolder(folder) {
if (!_isFolder(folder)) {
try {
fso.CreateFolder(folder);
} catch (e) {
return false;
return _isFolder(folder);
return false;
function _deleteFile(file) {
try {
fso.DeleteFile(file);
} catch (e) {
return false;
return !(_isFile(file));
return false;
function _renameFile(file, newFilePath) {
if (!_isFile(newFilePath) {
try {
fso.MoveFile(file, newFilePath);
} catch (e) {
return false;
return _isFile(newFilePath);
return false;
return false;
try {
} catch (e) {
return false;
return false;
function _restoreFile(file) {
if (!_isFile(file)) {
const arr = utils.FileTest(file, "split");
const OriginalFileName = arr[1];
const items = app.NameSpace(10).Items();
const numItems = items.Count;
for (let i = 0; i < numItems; i++) {
if (items.Item(i).Name == OriginalFileName) {
_renameFile(items.Item(i).Path, file);
break;
let bFound = _isFile(file);
if (!bFound){console.log('_restoreFile(): Can not restore file, "' + OriginalFileName + '" was not found at the bin.');}
return bFound;
} else {
console.log('_restoreFile(): Can not restore file to "' + file + '" since there is already another file at the same path.');
return false;
Btw utils.FileTest() seems to have a bug.
let arr = utils.FileTest("D:\\Somedir\\Somefile.txt", "split")
// arr[1] <= "Somefile.txt" extension included (?)
Not sure if that's intended, but the documentation says otherwise:
let arr = utils.FileTest("D:\\Somedir\\Somefile.txt", "split");
// arr[0] <= "D:\\Somedir\\" (always includes backslash at the end)
// arr[1] <= "Somefile"
// arr[2] <= ".txt"
PD: For reference, if that behaviour get's fixed, then the scripts at top should reflect that change too.
Reply #617
let popup = {
ok : 0,
yes_no : 4,
yes : 6,
no : 7,
stop : 16,
question : 32,
info : 64
let prompt = ...
let caption = ...
//do something
Oh that... yes. That's why I asked, I was sure I have been seeing them somewhere! I would prefer to not use ActiveXobjects but it's good enough. Thanks!
Reply #618
I can see the bug with utils.FileTest here...
https://github.com/TheQwertiest/foo_spider_monkey_panel/blob/150e49cdc072762b1a6b6a90d7e5be1158bbba50/foo_spider_monkey_panel/js_objects/utils.cpp#L298
It should use stem(), not filename().
Reply #619
Finally got all working on the playlist manager, and managed to get playlist size (#tracks) by using m3u directives and/or counting lines if they are missing. But I have a limitation, I can easily read/write m3u, m3u8 files and create schemes for them but I have no way to read fpl files.
If I want to know the number of tracks from a fpl playlist, is there any other way other than loading the playlist within foobar, and using plman.PlaylistItemCount(index)t?
I mean, is there a way to bypass playlist loading into the UI? fpl -> Handle list
EDIT: since addLocations(playlistIndex, paths, selectopt)  is async and there is no other method to load a playlist, the mentioned method doesn't work since PlaylistItemCount returns 0 because the playlist loading is not done yet when called. And having in mind all this involves playlist being temporarily shown on the UI, I think I should avoid using promises for creating/count/deleting temp playlists.
Reply #621
Another bug:
I have folder with these files:
c:\Users\XXX\AppData\Roaming\foobar2000\playlist_manager\Lucia Emotivas.fpl
c:\Users\XXX\AppData\Roaming\foobar2000\playlist_manager\Post-Britpop.m3u8
c:\Users\XXX\AppData\Roaming\foobar2000\playlist_manager\World.m3u
utils.Glob(folderPath + '*.m3u').concat(utils.Glob(folderPath + '*.m3u8')).concat(utils.Glob(folderPath + '*.fpl')).concat(utils.Glob(folderPath + '*.pls'));
On console, win 7, there are 4 files:
[15:11:36] ["C:\Users\XXX\AppData\Roaming\foobar2000\playlist_manager\Post-Britpop.m3u8", "C:\Users\XXX\AppData\Roaming\foobar2000\playlist_manager\World.m3u", "C:\Users\XXX\AppData\Roaming\foobar2000\playlist_manager\Post-Britpop.m3u8", "C:\Users\XXX\AppData\Roaming\foobar2000\playlist_manager\Lucia Emotivas.fpl"]
Same script on win 10: 3 files
[15:11:36] ["C:\Users\XXX\AppData\Roaming\foobar2000\playlist_manager\World.m3u", "C:\Users\XXX\AppData\Roaming\foobar2000\playlist_manager\Post-Britpop.m3u8", "C:\Users\XXX\AppData\Roaming\foobar2000\playlist_manager\Lucia Emotivas.fpl"]
utils.Glob(folderPath + '*.m3u') matches '*.m3u8' too on win 7.
Reply #622
Seems like its not a component bug but a windows API issue.
But you can just use *.* and filter by extension yourself.
const allowed = ["m3u", "m3u8", "pls", "fpl"];
let files = utils.Glob("z:\\*.*").filter((item) => {
return allowed.includes(item.split('.').pop().toLowerCase());
Reply #623
Yep, I did something similar.
@TheQwertiest  Also check PathWildcardMatch(), since being a bug with the API it probably has the same behavior. If you need testing on win 7 just let me know, I use both.
