Topic: CUE sheet track limit (Read 814 times) previous topic - next topic
I know that CUE sheets are supposed to be limited to a maximum of 99 tracks.  Is there a workaround for this?
Re: CUE sheet track limit
"Raised track count limit for cue sheets from 99 to 999." - from foobar2000 v1.4 changelog.
foobar2000 plays music
Thanks, I've been using v1.4 since it was released, and I wasn't aware of that.  But that being the case, it seems foobar2000's handling of large track lists is buggy, as it doesn't save the correct "Artist" info when embedding the CUE sheet -- only that of the last 100 tracks.  For example, if my FLAC file has 125 tracks, #26 through #125 will be correct, but track #1-25 will feature the artist info from track #101-125.  And editing those tracks' properties manually doesn't work either -- the "Artist" field still reverts to that of the Track Number plus 100.
Maybe mods should move this to the fb2k forums? (And delete this post.)
