Topic: metadb_index_client questions (Read 448 times) previous topic - next topic
Hey there!
I'm trying to to implement custom metadb_index_client, but for some reason `metadb_index_manager::get()->add();` fails with invalid argument exception during it's initialization.
The code was mostly (99.99%) copy-pasted from marc2003's foo_jscript_panel (which does not share this problem). The only thing that was changed is GUID for the metadb_index_client to avoid possible collision.
The code in question: https://github.com/TheQwertiest/foo-jscript-panel/blob/master/foo_spider_monkey_panel/stats.h#L46
Any help would be greatly appreciated!
... summons @Peter ...
Re: metadb_index_client questions
init_stages::before_config_read seems awfully early in the process for most services to be available.
The definition of objects with static storage duration in your stats.h seems a bit sketchy as you include that header in multiple translation units and as such, have duplicate registrations of objects.
Welp, the code is mostly identical to the official sample:
https://github.com/zao/foo_wave_seekbar/blob/9138c3a79f3a7ed55a6bc6f915c40742a0372631/foobar2000/foo_sample/rating.cpp#L92
Do you know if there is a better example?
Yes, this is most likely the cause, thanks!
Ah, didn't know that was taken directly from foo_sample.
Note that my foo_wave_seekbar repository may not be up to date with the current SDK, but it's assumedly Good Enough.
