Topic: Newbie in foobar (Read 299 times) previous topic - next topic
Newbie in foobar
Hello ppl, i'm a winamp fanboy since the old times and everytime i tried foobar i never get the library to work as i want.
Basically my music folder structure is;
>MP3 Folder
      >Genre 1
           >Artist - Album - Year - ID (release name, ripping method or other stuff)
      >Genre 2
Then on my winamp plugin i see the albuns like this:
https://imgur.com/a/WHQMvIU
Is there any easy config to do the same in foobar?
Re: Newbie in foobar
Hi there,
Folder structure perhaps does not matter as music is generally sorted by tags (although you can use folders).
Try the foo_facets plug-in to have a column based library view. You could make a column that combines %artist% - %album% rather than having them in separate columns. Then enable multiple columns and add a %date% one. See the documentation for help.
Cheers 8)
thanks for the help...the problem is "just" to use de folder name as an item on library, the year on another column it's not a problem for me.
i want the library to detect folder with media and add them to library parsin the folder name (artist - album - year - stuff)
wow...it's was so simple as put "%_directoryname%|%tracknumber%. %artist% - %title%" as view script.
next step will be to parse one by one...
$puts(index, $strstr(%_directoryname%,' - ')) >
$put(artista, $substr(%_directoryname%,0,index)) >
$puts(resto, $substr(%_directoryname%,index, $len(%_directoryname%)))
$puts(index, $strstr($get(resto),' - '))
$put(album, $substr($get(resto),0,index))
$puts(resto, $substr($get(resto),$get(index), $len($get(resto))))
$put(year, $substr($get(resto),0,index))
$put(resto, $substr($get(resto),$get(index), $len($get(resto))))
not working but i'll get there.
thanks anamorphic to alert me to documentation from a component!
