Topic: Checking for updates (Read 484 times) previous topic - next topic
Edit: I probably should have posted this in the Support forum, but I'm easily confused. I couldn't work out how to delete this thread and start again, so if a mod cares to move it....
It might be a Windows XP thing, but I thought I'd ask.
When I checked for component updates with version 1.3.17, it found some and offered to install them. For version 1.4, the following error message appears.
Could not check for updates: Network authentication error (80090328)
Checking for a new foobar2000 version with 1.3.17 opens a browser window/tab here:
http://www.foobar2000.org/download
I'm pretty sure 1.4 has only offered the following message since the first beta and it failed to report the release of the stable version.
No new version available at this time.
As I have 1.3.17 installed as a portable version, I did the same for 1.4 to confirm it still behaved the same way, which it did.
Re: Checking for updates
Works for me.
Are you sure you're running 1.4 stable not a beta version?
OK, problem recreated.
Specifically, error appears if you check for updates and there are updates for installed components. A correct response is shown if all the components are already up to date.
This will be fixed in 1.4.1, thanks for reporting.
Awesome! Thank you.
