Topic: help with playlists search  (Read 480 times) previous topic - next topic
I haven't found anything around about this... Two things I'm trying to do with Foobar and cannot understand how (or if it is even possible):
- is there a way to search througout ALL PLAYLISTS (not the library: my list of albums is populated mainly by online items, retrieved in youtube via foo_youtube component)? With Ctrl+F (Playlist search) it focuses the research only in the active playlist.
- is it possibile somehow to search the playlist's name? I mean, not the name of the file (since there is no file: as I said, most of my items are "urls" from youtube), the name that I gave to the playlist in Foobar.
OS: windows 10
Foobar2000 version: v1.3.17
Thank you,
Andrea
Re: help with playlists search
Hi there,
Not sure these are possible with standard foobar. Have a look at foo_quicksearch plug-in might do the trick.
Cheers 8)
Thank you,
I tried it, and it is not the best solution: it does search throughout the entire playlists collection BUT
- it doesn't find the playlist's titles (it focuses only on the songs)
- and it creates another playlist with the items found (which makes no sense to me, since I want to find in my playlists collection an already existing playlist)... What seems more logical to me would be a search window where a list of results appears, and by clicking to the wanted item, the focus jumps where the item is (or it highlights it) in its actual position.
