Topic: Button "Stop after current" (Read 601 times) previous topic - next topic
Hello everybody,
I need a button, which is usually grayed out. If you click on it, "Stop after current" is activated and the button turns red. If you click again on it "Stop after current" deactivated and the button again gray. After completing the track, "Stop after Current" is automatically turned off. This should also be indicated by the gray button again. I know that you can do it with JScript (see Tedgos Darkone, button and indicator in the panel). Can someone write a code ??? I tried to "cut" Tedgos, but then it hails only error messages.
I think that many want to use that, even if they use the DUI.
Thank you
LG Frank
Re: Button "Stop after current"
An inikator gray or red would be enough for me.
