Topic: SuperFast LAME multi-threaded MP3 encoder (Read 4185 times) previous topic - next topic
Hi folks,
I just published the 3rd preview release of fre:ac with my SuperFast multi-threading technology. You can download it from GitHub.
This release adds support for multi-threaded LAME MP3 encoding. It scales very well with the number of CPU cores and can achieve a 3.5x speed-up on a quad core CPU. On my i7-6900K, I was able to measure up to 12x speed-up when running with all 16 threads (in most scenarios, however, either decoding or HDD/SSD speed will be a bottleneck before going to such speeds).
Two key points distinguish SuperFast LAME from previous attempts to build multi-threaded MP3 encoders:
  • It keeps the bit-reservoir enabled in order to achieve the same quality as the original encoder.
  • It uses an unmodified LAME encoder library, so the encoder can be swapped out for your own version.
Making it work while keeping the bit-reservoir enabled was actually the greatest challenge. Here is a technical article on how this is implemented: SuperFast LAME technical details
I plan to implement this technology on top of the command line LAME frontend in the future. For now, my priority is on releasing fre:ac 1.1 beta and final versions, though.
Thanks in advance for trying the preview and posting your results and opinions!
Re: SuperFast LAME multi-threaded MP3 encoder
Interesting!
Bravo! I shall try this out in the upcoming weeks and let you know of the results.
