Topic: Beats Per Minute (Read 1962 times) previous topic - next topic
Beats Per Minute
   How can I add a heading for BPM? The data is readily available from Mixmeister or other sites. I just don't see a method for doing it.
Re: Beats Per Minute
By heading, do you mean a tag to an audio file? --- I'm not sure if there's a way to have Foobar write BPM data to a file's tags unless the tag information already existed in the source file.
Or are you trying to add a custom attribute to Foobar's GUI? --- If this is true, then try %BPM%, if that doesn't work, then try $meta(BPM)
-- Brought to you by the guy, alone in the corner, converting all his files to lossless formats...
You should specify your player, but I'm going to assume Foobar2000. There's a BPM analyzer and you can just add a column with %BPM% as Isaac says. I have all of my music analyzed and exposed that way; the analyzer is a bit idiosyncratic, but it has an easy double/half that takes care of almost all of the misdetections. You can easily add the field to the tag editor as well.
