From foobar2000 v1.4 beta 13 (more or less) bluescreens of death
I had this problem, whenever I installed a beta version which was what I was using until I had this problem. I had BSoD so I started using the regular one and no problems.
If you need it this is the minidump.
ntoskrnl.exe ntoskrnl.exe+ebcf2 fffff800`02e14000 fffff800`033fa000 0x005e6000 0x5915f59a 12/05/2017 18:49:14 Microsoft® Windows® Operating System NT Kernel & System 6.1.7601.23807 (win7sp1_ldr.170512-0600) Microsoft Corporation C:\Windows\system32\ntoskrnl.exe
tcpip.sys tcpip.sys+60726 fffff880`01a03000 fffff880`01bff000 0x001fc000 0x592cf25e 30/05/2017 5:17:34
hal.dll fffff800`033fa000 fffff800`03443000 0x00049000 0x4ce7c669 20/11/2010 14:00:25
kdcom.dll fffff800`00b9f000 fffff800`00ba9000 0x0000a000 0x4d4d8061 05/02/2011 17:52:49
mcupdate_GenuineIntel.dll fffff880`00cf3000 fffff880`00d42000 0x0004f000 0x4ce7c737 20/11/2010 14:03:51
PSHED.dll fffff880`00d42000 fffff880`00d56000 0x00014000 0x4a5be027 14/07/2009 2:32:23 Sistema operativo Microsoft® Windows® Controlador de errores de hardware específicos de la plataforma 6.1.7600.16385 (win7_rtm.090713-1255) Microsoft Corporation C:\Windows\system32\PSHED.dll
CLFS.SYS fffff880`00d56000 fffff880`00db5000 0x0005f000 0x593f1196 12/06/2017 23:11:34
CI.dll fffff880`00c00000 fffff880`00c75000 0x00075000 0x53acd215 27/06/2014 3:08:21
Wdf01000.sys fffff880`00eb7000 fffff880`00f79000 0x000c2000 0x51c51641 22/06/2013 4:13:05
WDFLDR.SYS fffff880`00f79000 fffff880`00f89000 0x00010000 0x5010ab70 26/07/2012 3:29:04
ACPI.sys fffff880`00f89000 fffff880`00fe0000 0x00057000 0x4ce79294 20/11/2010 10:19:16
WMILIB.SYS fffff880`00fe0000 fffff880`00fe9000 0x00009000 0x4a5bc117 14/07/2009 0:19:51
msisadrv.sys fffff880`00fe9000 fffff880`00ff3000 0x0000a000 0x4a5bc0fe 14/07/2009 0:19:26
pci.sys fffff880`00e00000 fffff880`00e33000 0x00033000 0x4ce7928f 20/11/2010 10:19:11
vdrvroot.sys fffff880`00e33000 fffff880`00e40000 0x0000d000 0x4a5bcadb 14/07/2009 1:01:31
partmgr.sys fffff880`00e40000 fffff880`00e55000 0x00015000 0x4f641bc1 17/03/2012 6:06:09
compbatt.sys fffff880`00e55000 fffff880`00e5e000 0x00009000 0x4a5bc3b6 14/07/2009 0:31:02
BATTC.SYS fffff880`00e5e000 fffff880`00e6a000 0x0000c000 0x4a5bc3b5 14/07/2009 0:31:01
volmgr.sys fffff880`00e6a000 fffff880`00e7f000 0x00015000 0x4ce792a0 20/11/2010 10:19:28
volmgrx.sys fffff880`00c75000 fffff880`00cd1000 0x0005c000 0x00000000
mountmgr.sys fffff880`00e7f000 fffff880`00e99000 0x0001a000 0x590f3498 07/05/2017 15:52:08
atapi.sys fffff880`00e99000 fffff880`00ea2000 0x00009000 0x4a5bc113 14/07/2009 0:19:47
ataport.SYS fffff880`00db5000 fffff880`00ddf000 0x0002a000 0x51fef9b5 05/08/2013 2:02:45
msahci.sys fffff880`00ea2000 fffff880`00ead000 0x0000b000 0x4ce7a416 20/11/2010 11:33:58
PCIIDEX.SYS fffff880`00ddf000 fffff880`00def000 0x00010000 0x4a5bc114 14/07/2009 0:19:48
amdxata.sys fffff880`00ff3000 fffff880`00ffe000 0x0000b000 0x4ba3a3ca 19/03/2010 17:18:18
fltmgr.sys fffff880`010cd000 fffff880`01119000 0x0004c000 0x4ce7929c 20/11/2010 10:19:24
fileinfo.sys fffff880`01119000 fffff880`0112d000 0x00014000 0x4a5bc481 14/07/2009 0:34:25
cng.sys fffff880`01379000 fffff880`013ee000 0x00075000 0x583077df 19/11/2016 17:03:43
avc3.sys fffff880`01434000 fffff880`015d7000 0x001a3000 0x5a71e67e 31/01/2018 16:53:34
gzflt.sys fffff880`01200000 fffff880`0123a000 0x0003a000 0x5a60a3be 18/01/2018 14:40:14
Ntfs.sys fffff880`01640000 fffff880`017e7000 0x001a7000 0x593ab68d 09/06/2017 15:54:05
msrpc.sys fffff880`0112d000 fffff880`0118b000 0x0005e000 0x00000000
ksecdd.sys fffff880`01600000 fffff880`0161b000 0x0001b000 0x593f1195 12/06/2017 23:11:33
pcw.sys fffff880`0161b000 fffff880`0162c000 0x00011000 0x4a5bc0ff 14/07/2009 0:19:27
Fs_Rec.sys fffff880`0162c000 fffff880`01636000 0x0000a000 0x00000000
ndis.sys fffff880`0186f000 fffff880`01962000 0x000f3000 0x561c7ad7 13/10/2015 4:30:31
NETIO.SYS fffff880`01962000 fffff880`019c3000 0x00061000 0x592cf23c 30/05/2017 5:17:00
ksecpkg.sys fffff880`019c3000 fffff880`019ee000 0x0002b000 0x593f1363 12/06/2017 23:19:15
fwpkclnt.sys fffff880`01800000 fffff880`01849000 0x00049000 0x592cf231 30/05/2017 5:16:49
volsnap.sys fffff880`0118b000 fffff880`011d7000 0x0004c000 0x4ce792c8 20/11/2010 10:20:08
spldr.sys fffff880`01849000 fffff880`01851000 0x00008000 0x4a0858bb 11/05/2009 17:56:27
rdyboost.sys fffff880`01000000 fffff880`0103a000 0x0003a000 0x4ce7982e 20/11/2010 10:43:10
mup.sys fffff880`01851000 fffff880`01863000 0x00012000 0x4a5bc201 14/07/2009 0:23:45
hwpolicy.sys fffff880`01863000 fffff880`0186c000 0x00009000 0x4ce7927e 20/11/2010 10:18:54
fvevol.sys fffff880`0103a000 fffff880`01074000 0x0003a000 0x5100a65c 24/01/2013 4:11:24
disk.sys fffff880`017e7000 fffff880`017fc000 0x00015000 0x569eecf6 20/01/2016 3:12:06
CLASSPNP.SYS fffff880`01400000 fffff880`01430000 0x00030000 0x4ce7929b 20/11/2010 10:19:23
bddci.sys fffff880`01074000 fffff880`0109e000 0x0002a000 0x5a6f0072 29/01/2018 12:07:30
cdrom.sys fffff880`0124d000 fffff880`01277000 0x0002a000 0x4ce79298 20/11/2010 10:19:20
Null.SYS fffff880`01636000 fffff880`0163f000 0x00009000 0x00000000
Beep.SYS fffff880`015ee000 fffff880`015f5000 0x00007000 0x4a5bca8d 14/07/2009 1:00:13
vga.sys fffff880`01277000 fffff880`01285000 0x0000e000 0x4a5bc587 14/07/2009 0:38:47
VIDEOPRT.SYS fffff880`01285000 fffff880`012aa000 0x00025000 0x4a5bc58b 14/07/2009 0:38:51
watchdog.sys fffff880`012aa000 fffff880`012ba000 0x00010000 0x4a5bc53f 14/07/2009 0:37:35
RDPCDD.sys fffff880`015f5000 fffff880`015fe000 0x00009000 0x4a5bce62 14/07/2009 1:16:34
rdpencdd.sys fffff880`012ba000 fffff880`012c3000 0x00009000 0x4a5bce62 14/07/2009 1:16:34
rdprefmp.sys fffff880`012c3000 fffff880`012cc000 0x00009000 0x4a5bce63 14/07/2009 1:16:35
Msfs.SYS fffff880`012cc000 fffff880`012d7000 0x0000b000 0x00000000
Npfs.SYS fffff880`012d7000 fffff880`012e8000 0x00011000 0x4a5bc114 14/07/2009 0:19:48
tdx.sys fffff880`012e8000 fffff880`0130a000 0x00022000 0x59132936 10/05/2017 15:52:38
TDI.SYS fffff880`0130a000 fffff880`01317000 0x0000d000 0x4ce7933e 20/11/2010 10:22:06
afd.sys fffff880`03c12000 fffff880`03c9b000 0x00089000 0x58e3b35c 04/04/2017 15:53:16
netbt.sys fffff880`03c9b000 fffff880`03ce0000 0x00045000 0x5733488e 11/05/2016 15:58:22
wfplwf.sys fffff880`03ce0000 fffff880`03ce9000 0x00009000 0x4a5bccb6 14/07/2009 1:09:26
pacer.sys fffff880`03ce9000 fffff880`03d0f000 0x00026000 0x4ce7a862 20/11/2010 11:52:18
netbios.sys fffff880`03d0f000 fffff880`03d1e000 0x0000f000 0x4a5bccb6 14/07/2009 1:09:26
wanarp.sys fffff880`03d1e000 fffff880`03d39000 0x0001b000 0x4ce7a874 20/11/2010 11:52:36
termdd.sys fffff880`03d39000 fffff880`03d4d000 0x00014000 0x4ce7ab0c 20/11/2010 12:03:40
rdbss.sys fffff880`03d4d000 fffff880`03d9e000 0x00051000 0x4ce79497 20/11/2010 10:27:51
nsiproxy.sys fffff880`03d9e000 fffff880`03daa000 0x0000c000 0x4a5bc15e 14/07/2009 0:21:02
mssmbios.sys fffff880`03daa000 fffff880`03db5000 0x0000b000 0x4a5bc3be 14/07/2009 0:31:10
discache.sys fffff880`03db5000 fffff880`03dc4000 0x0000f000 0x4a5bc52e 14/07/2009 0:37:18
dfsc.sys fffff880`03dc4000 fffff880`03de3000 0x0001f000 0x57d17bd1 08/09/2016 15:55:13
blbdrive.sys fffff880`03de3000 fffff880`03df4000 0x00011000 0x4a5bc4df 14/07/2009 0:35:59
tunnel.sys fffff880`01317000 fffff880`0133d000 0x00026000 0x4ce7a846 20/11/2010 11:51:50
igdkmd64.sys fffff880`03ed6000 fffff880`043f3c20 0x0051dc20 0x55653fae 27/05/2015 4:53:18
dxgkrnl.sys fffff880`0446d000 fffff880`04562000 0x000f5000 0x591b136f 16/05/2017 15:57:51
dxgmms1.sys fffff880`04562000 fffff880`045a8000 0x00046000 0x591b135e 16/05/2017 15:57:34
HECIx64.sys fffff880`045a8000 fffff880`045b9000 0x00011000 0x4cbe2ad7 20/10/2010 0:33:43
usbehci.sys fffff880`045b9000 fffff880`045cb000 0x00012000 0x57b37a2c 16/08/2016 21:40:12
USBPORT.SYS fffff880`04400000 fffff880`04457000 0x00057000 0x57b37a2b 16/08/2016 21:40:11
HDAudBus.sys fffff880`045cb000 fffff880`045ef000 0x00024000 0x4ce7a65e 20/11/2010 11:43:42
Rt64win7.sys fffff880`04a3a000 fffff880`04b37000 0x000fd000 0x56e25be6 11/03/2016 6:47:18
i8042prt.sys fffff880`04b37000 fffff880`04b55000 0x0001e000 0x4a5bc11d 14/07/2009 0:19:57
kbdclass.sys fffff880`04b55000 fffff880`04b64000 0x0000f000 0x4a5bc116 14/07/2009 0:19:50
intelppm.sys fffff880`04b64000 fffff880`04b7a000 0x00016000 0x4a5bc0fd 14/07/2009 0:19:25
CompositeBus.sys fffff880`04b7a000 fffff880`04b8a000 0x00010000 0x4ce7a3ed 20/11/2010 11:33:17
AgileVpn.sys fffff880`04b8a000 fffff880`04ba0000 0x00016000 0x4a5bccf0 14/07/2009 1:10:24
rasl2tp.sys fffff880`04ba0000 fffff880`04bc4000 0x00024000 0x4ce7a872 20/11/2010 11:52:34
ndistapi.sys fffff880`04bc4000 fffff880`04bd0000 0x0000c000 0x4a5bccd8 14/07/2009 1:10:00
ndiswan.sys fffff880`04bd0000 fffff880`04bff000 0x0002f000 0x4ce7a870 20/11/2010 11:52:32
raspppoe.sys fffff880`04a00000 fffff880`04a1b000 0x0001b000 0x4a5bcce9 14/07/2009 1:10:17
raspptp.sys fffff880`03e00000 fffff880`03e21000 0x00021000 0x4ce7a86f 20/11/2010 11:52:31
rassstp.sys fffff880`04a1b000 fffff880`04a35000 0x0001a000 0x4a5bccf1 14/07/2009 1:10:25
mouclass.sys fffff880`045ef000 fffff880`045fe000 0x0000f000 0x4a5bc116 14/07/2009 0:19:50
BazisVirtualCDBus.sys fffff880`03e21000 fffff880`03e50000 0x0002f000 0x560759b0 27/09/2015 3:51:28
swenum.sys fffff880`04a35000 fffff880`04a36480 0x00001480 0x4a5bca92 14/07/2009 1:00:18
ks.sys fffff880`03e50000 fffff880`03e93000 0x00043000 0x4ce7a3f3 20/11/2010 11:33:23
umbus.sys fffff880`04457000 fffff880`04469000 0x00012000 0x4ce7a695 20/11/2010 11:44:37
usbhub.sys fffff880`04cdd000 fffff880`04d37000 0x0005a000 0x57b37a39 16/08/2016 21:40:25
NDProxy.SYS fffff880`04d37000 fffff880`04d4c000 0x00015000 0x4ce7a864 20/11/2010 11:52:20
RTKVHD64.sys fffff880`04e0d000 fffff880`05290000 0x00483000 0x5582a131 18/06/2015 11:45:05
portcls.sys fffff880`05290000 fffff880`052cd000 0x0003d000 0x56671d76 08/12/2015 19:12:06
drmk.sys fffff880`052cd000 fffff880`052ef000 0x00022000 0x5667276c 08/12/2015 19:54:36
ksthunk.sys fffff880`052ef000 fffff880`052f4200 0x00005200 0x4a5bca93 14/07/2009 1:00:19
HdAudio.sys fffff880`052f5000 fffff880`05351000 0x0005c000 0x4ce7a687 20/11/2010 11:44:23
USBSTOR.SYS fffff880`05351000 fffff880`0536c000 0x0001b000 0x56b241ca 03/02/2016 19:07:06
USBD.SYS fffff880`0536c000 fffff880`0536de80 0x00001e80 0x57b37a26 16/08/2016 21:40:06
win32k.sys fffff960`00080000 fffff960`003a7000 0x00327000 0x00000000
Dxapi.sys fffff880`0536e000 fffff880`0537a000 0x0000c000 0x4a5bc574 14/07/2009 0:38:28
hidusb.sys fffff880`05388000 fffff880`05396000 0x0000e000 0x4ce7a665 20/11/2010 11:43:49
HIDCLASS.SYS fffff880`05396000 fffff880`053af000 0x00019000 0x51d3a2f1 03/07/2013 5:05:05
HIDPARSE.SYS fffff880`053af000 fffff880`053b7080 0x00008080 0x51d3a2f0 03/07/2013 5:05:04
mouhid.sys fffff880`053b8000 fffff880`053c5000 0x0000d000 0x4a5bca94 14/07/2009 1:00:20
TSDDD.dll fffff960`00430000 fffff960`0043a000 0x0000a000 0x00000000
crashdmp.sys fffff880`053c5000 fffff880`053d3000 0x0000e000 0x4a5bcabd 14/07/2009 1:01:01
dump_dumpata.sys fffff880`053d3000 fffff880`053df000 0x0000c000 0x4a5bc113 14/07/2009 0:19:47
dump_msahci.sys fffff880`053df000 fffff880`053ea000 0x0000b000 0x4ce7a416 20/11/2010 11:33:58
dump_dumpfve.sys fffff880`053ea000 fffff880`053fd000 0x00013000 0x4a5bc18f 14/07/2009 0:21:51
cdd.dll fffff960`00750000 fffff960`00777000 0x00027000 0x00000000
luafv.sys fffff880`04d4c000 fffff880`04d6f000 0x00023000 0x4a5bc295 14/07/2009 0:26:13
trufos.sys fffff880`04c00000 fffff880`04c99000 0x00099000 0x5ade00ee 23/04/2018 16:51:10
lltdio.sys fffff880`04c99000 fffff880`04cae000 0x00015000 0x4a5bcc92 14/07/2009 1:08:50
rspndr.sys fffff880`04cae000 fffff880`04cc6000 0x00018000 0x4a5bcc92 14/07/2009 1:08:50
HTTP.sys fffff880`048d4000 fffff880`0499c000 0x000c8000 0x5942ecd1 15/06/2017 21:23:45
bowser.sys fffff880`0499c000 fffff880`049b9000 0x0001d000 0x57f51433 05/10/2016 15:54:43
mpsdrv.sys fffff880`049b9000 fffff880`049d1000 0x00018000 0x4a5bcc79 14/07/2009 1:08:25
mrxsmb.sys fffff880`049d1000 fffff880`049fe000 0x0002d000 0x593f11e0 12/06/2017 23:12:48
mrxsmb10.sys fffff880`04800000 fffff880`0484e000 0x0004e000 0x593f11c0 12/06/2017 23:12:16
mrxsmb20.sys fffff880`0484e000 fffff880`04872000 0x00024000 0x593f11be 12/06/2017 23:12:14
peauth.sys fffff880`05a4a000 fffff880`05af4000 0x000aa000 0x57603aaa 14/06/2016 18:11:06
srvnet.sys fffff880`05af4000 fffff880`05b25000 0x00031000 0x58e5055a 05/04/2017 15:55:22
tcpipreg.sys fffff880`05b25000 fffff880`05b37000 0x00012000 0x577e7056 07/07/2016 16:08:06
srv2.sys fffff880`05b37000 fffff880`05b9f000 0x00068000 0x58e5055f 05/04/2017 15:55:27
srv.sys fffff880`0600f000 fffff880`060a4000 0x00095000 0x58e50566 05/04/2017 15:55:34
fastfat.SYS fffff880`060a4000 fffff880`060da000 0x00036000 0x58c2cc6e 10/03/2017 16:55:26
atc.sys fffff880`060da000 fffff880`061fb000 0x00121000 0x5a9e757c 06/03/2018 12:03:24
WudfPf.sys fffff880`05b9f000 fffff880`05bb8000 0x00019000 0x5010aae5 26/07/2012 3:26:45
WUDFRd.sys fffff880`05bb8000 fffff880`05bee000 0x00036000 0x5010aabe 26/07/2012 3:26:06
edrsensor.sys fffff880`05a00000 fffff880`05a3b000 0x0003b000 0x5a0c2856 15/11/2017 12:43:18
cdfs.sys fffff880`04885000 fffff880`048a2000 0x0001d000 0x4a5bc112 14/07/2009 0:19:46
monitor.sys fffff880`06000000 fffff880`0600e000 0x0000e000 0x4a5bc58c 14/07/2009 0:38:52
WinUsb.sys fffff880`05bee000 fffff880`05bff000 0x00011000 0x4ce7a66c 20/11/2010 11:43:56
