Topic: Least Squares noise shaping implementations? (Read 6770 times) previous topic - next topic
Has any decoder or player implemented Least Squares noise shaping algorithm?
It would be interesting to compare it personally with basic triangular dither, so common to all the decoders and players we use these days.
regards,
Halcyon
References:
LEAST SQUARES THEORY AND DESIGN OF OPTIMAL NOISE SHAPING FILTERS, AES 2002
http://www.etro.vub.ac.be/Research/DSSP/pu.../AES-2002-B.pdf
ON PSYCHOACOUSTIC NOISE SHAPING FOR AUDIO REQUANTIZATION, ICASS 2003
http://www.etro.vub.ac.be/Research/DSSP/pu...ICASSP-2003.pdf
I don't think it is implemented in any computer decoder or player. However, I don't think it is much worth the effort. Some players such as fb2k include ATH-shaped noise shaping profiles that can achieve a dynamic range equivalent to around 110 dB for 16-bit audio.
Thanks for the comment.
I'm not up-to-date on fb2k implementation. Is the noise shaping filter dynamically adjusted in relation to the input audio data?
That is the main point in the papers, although I was talking about th algorithm (least squares) method.
regards,
Halcyon
AFAIK fb2k uses SSRC noise shaping dithering, with some improvements to avoid clipping. There are a few different noise shaping profiles to choose, but for each one the spectral shape of the dither is fixed, not dynamic. As I said, I don't think dynamic noise shaping is implemented in any of the available computer decoders or players.
KikeG,
I'm sure you know this better than I do, but single dynamic range measurement is no proof of audible superiority of a noise shaping implementation.
As such, I'm a little surprised at your "it's not worth the effort" comment and would like you to explain your opinion better, if I have misunderstood you.
I think adaptive noise shaping listening tests have indicated already their possible audible superiority over constant noise shaping curve implementations (regardless of what the average measurements for dynamic range imply).
Best regards,
Halcyon
I read at least one of those articles a couple months ago (when I was working on noise shaping algorithms for WavPack's lossy mode) and you're right, they look very promising. I really think they're a much better way to go than adding all that energy above 15 kHz (which is how the static algorithms work), especially for coarse quanitization (like 8-bit or WavPack lossy). Unfortunately, I was not able to find enough information in the papers to implement the algorithms, and they might be very computationally intensive.
I said "equivalent" dynamic range. SSRC strong ATH noiseshaping with 16-bit output has a measured dynamic range of just around 70 dB, but an audible-equivalent dynamic range of around 110 dB, just due to the ATH shaped dither noise. I can't hear just this dither noise on my setup even putting the amp volume know at max, so...
As bryant says, this is probably clearly noticeable and worth the effort for low-resolution audio, such as for example when dithering to 8-bit. But for 16-bit audio under real-world listening conditions, I think a good static noiseshaping profile is already overkill.
It is significantly more computationally intensive than the current fb2k ditherer, but still fast enough for use in (for example) an audio player, as far as I can gather from the papers.
I haven't got the time to persue this right now, but if you need implementation details, contact the paper authors, and for example ask if they're willing to give out the source used for the papers tests.
Thanks for the clarification KikeG.
I was under the impression that dither needs to be evaluated along with signal and not by itself? Am I mistaken? Not that I'm trying to refute what you say, so please don't take this the wrong way.
You are probably right that it would only make sense for low bit depth requantisized signals as the paper's listening test demonstrates.
I already bumped into a patent on the issue (I think), so they probably won't give out details, but I can always ask
cheers,
Halcyon
The effectiveness of a dither algorithm, (meaning this how well does it remove quantization distortion whenever there's some requantization going on), can only be tested in presence of some signal that gets requantized.
But once you have a dither algorithm that does this properly, you can quickly evaluate the audibility of the dither noise just listening to this noise without any signal present.
The less audible this noise, the more it will get masked with signal, and the more it will be able to resolve low-level signals, since those signals will more easily fall over the dither noise floor.
Those dynamic noiseshaping algorithms are based in that the spectrum of the dither is adjusted in function of the signal, in order to maximize the masking of the signal over the dither noise floor.
Adaptive noise shapers have a big disadvantage called noise modulation.
That's why you also find a lot of papers which force not to use adaptive noise shapers,
because when noise becomes audible it disturbs much much more than a constant noise.
This constant noise can be adapted von title to title/album to album depending on the noise
footprint, but it should constant within a title/album.
Diocletian
Time Travel Agency
Book a journey to the Diocletian Palace. Not today!
