Topic: Georgia: A dynamically generated fb2k theme (Read 48076 times) previous topic - next topic
Re: Georgia: A dynamically generated fb2k theme
Reply #300
Since Georgia 2.0.0 the Spider Monkey Panel is required instead of the JScript Panel.
See the detailed Georgia installation instructions here.
Reply #301
Version 2.0.3 released.
Also added a video to explain some of the new cdArt options/settings:
https://www.youtube.com/watch?v=_jplUBlRNos
Reply #302
 How to only use the embedded album art ? I try the cdArt setting to but cant seem to work. My folder usually contain many images, I dont want to delete all of them.
Reply #303
 Nevermind, found the setting in .json file.
 Sorry for double post cuz I cant delete it  :'(
Reply #304
All good. I'm working on something that will hopefully improve the discoverability of some of these settings/features, but we'll see if it makes it off the ground.
Reply #305
@MordredKLB Can I change the upper font to look like the one at lower side ? The upper one is not looking good in my language.
X
Reply #306
If you look closely the bottom one also does not look correct. Those characters just aren't available in the font so it's falling back to a thicker font that does contain them.
Fortunately this can be changed fairly easily. First let's change lines 94-96 to a font that will hopefully work better than either:
	ft.title_lrg = font(fontLightAlternate, 34, 0);
ft.title_med = font(fontLightAlternate, 30, 0);
ft.title_sml = font(fontLightAlternate, 26, 0);
If that still doesn't improve things, change them to this which is the font currently being used on the bottom.
	ft.title_lrg = font(fontLight, 34, 0);
ft.title_med = font(fontLight, 30, 0);
ft.title_sml = font(fontLight, 26, 0);
Reply #307
This solution work, not perfect but I'm happy as it is. Thanks you very much ;) .
PS: It's done so pls ignore my PM  :D
Reply #308
Hello, this is my first post on this forum, so apologies if I am breaking any rule.
Is there any way to remove the big pause icon located at the center of the album cover? I don't want it to show while the song is paused, I want to see that artwork clearly during the pause.
Reply #309
It doesn't look like it's optional so as a workaround for now, you can browse the Georgia folder and browse inside js and open ui-components.js in a text editor.
On line 21, there is a function that starts with
    draw(gr) {
Insert this as the first line after it...
return;
Reply #310
Thank you. Definitely needs to be added as an option.
