Topic: multi-track files generation fails to create output file with long filename (Read 753 times) previous topic - next topic
I'm using foobar to process many music files contained in structured directories.
Each directory contains a FLACs file of a CD with CUE file.
The procedure automates foobar for:
1) opening cue sheet
2) chaining FLACs to obtain multi-track files
3) after conversion a lot of operation are performed automatically on input and output file ...
The name of output file is : WIP_CDImage_[%album artist% - ][%album%][ - %discnumber%_%totaldiscs%],
so the length of full path name of FLAC file can be very long.
When i launch conversion two dialog appear:
1) first "Converter Output" with flac name
2) second "Converter Status Report"
    Source: "E:\Musica\WIP\_FLAC\Jordie Savall\[] Mare Nostrum - Orient - Occident - Dialogues [Alia Vox AVSA 988] Figueras, Elmaleh, Hesperion XXI, Savall\Disc 1of2\WIP_CDImage_000 Mare Nostrum (Disc 1).cue" / index: 1
   Unable to open file for writing (Object not found) : "E:\Musica\WIP\_FLAC\Jordie Savall\[] Mare Nostrum - Orient - Occident - Dialogues [Alia Vox AVSA 988] Figueras, Elmaleh, Hesperion XXI, Savall\Disc 1of2\WIP_CDImage_Various - Mare Nostrum- Orient - Occident Dialogues- Dialogue des musiques chretiennes,... - 1_2.flac"
   Conversion failed: Object not found
Full Path name is long 271 chars and chaining fails. If I, manually, truncate file name, conversion ends correctly.
It's possible to solve this bug ?
thank you
Re: multi-track files generation fails to create output file with long filename
This is not foobar2000's bug. This is Windows limitation.
You can use function $cut in titleformatting to automatically limit file name length.
Thank you for your answer. I solved my problem.
A question, usually i use APIs to write data to file having fullpath greater than MAX_PATH, therefore what do you mean with Windows limitations ?
It's actually file system limit. NTFS allows long paths but each component is limited to 255 characters. Majority of file systems have similar or more strict limit for this.
