Topic: How to configure ffmpeg to export spectrogram with information of the audio file (Read 912 times) previous topic - next topic
I created the spectrogram for the audio file in ffmpeg, but it's not display the informations as I wish.
My code in BAT file:
set MyFiles=*.flac *.wav *.aif
FOR %%A IN (%MyFiles%) DO ffmpeg -i "%%A" -y -lavfi showspectrumpic=s=1100x500:mode=separate "%%~nxA.png"
Is there a way to configure ffmpeg, display spectrogram like image below:
(Display Frequency 22 kHz; Title in spectrogram | bitrate kbps | samplerate Hz | bitspersample bit | Channels )
Can someone help please?
Thanks for any guidance.
Re: How to configure ffmpeg to export spectrogram with information of the audio file
Only sample rate and channels(layout) are available to filter, but you could use additional filter like drawtext to write all info.
Great! Thank you very much!
I have inserted the title in spectrogram:
-vf drawtext=text='%%A':x=(w-tw)/2:y=(h-th)/2:fontfile=OpenSans-Regular.ttf
But parameters as: bitrate kbps | samplerate Hz | bitspersample bit | Channels
I did not found them in "ffmpeg -h"
Could you please guide me as how to insert code?
You could extract them with ffprobe.
How to use this on the command line for just one file?
I just tried this:
ffmpeg -i infile.flac -lavfi showspectrumpic=s=1400x800:mode=separate outfile.png
Works, but does not cover the full frequency spectrum. Any ideas?
I just tried this:
The height in your case must be power of 2.
That explains it, thanks. (Now using 1024 instead of 800)
Hm... isn't ffplay better solution than ffmpeg?
ffplay, as name tells plays files only.
Exactly. So, I am using ffplay for previews inside my batch file when want to see the final result of that what ffmpeg will do for me before it start.
