Topic: Waveform Minibar (mod) (Read 24955 times) previous topic - next topic
Re: Waveform Minibar (mod)
Reply #150
Have you tried simulating it by setting the RMS color to black and regular color to dark gray?
Yes, it makes no big difference, the sharp edges are still there.
Reply #152
Hello,
how can I temporarily DISABLE the components waveform generation?
Atm, I work wtih huge files on a network drive which is not the fastest.
It takes about 10-30 seconts per file to scan.
I have enabled "abort seekbar generation... realtime", but its not aborting and I don't want the generation to be started at all.
The option "track to prefer, when showing waveform" does not have a good solution for me. (I need to switch between playing, skipping, playing other sounds, etc.)
I just like to disable the generation completely, but it seems not to be possible w/o uninstalling?
A right-click option "✔ disalble waveform generation" on the wavebar panel would be nice. (as a feature request)
As well as this:
I'm wondering too, if you could put the preferences "track to prefer when showing waveform" to the contextmenu (when rightclicking on the waveform), so users can switch fastly and do not need to open prefs, change setting, press ok, and change it back when needed, and open the prefs again for it..
I often like to change to "selected track", while my default setting is "playing, selected when stopped", but I don't want to stop the music ;-)) It could be faster to accomplish, with rightclick on waveform and quickly click one of the four entries.
Reply #153
There's "Halt minibar processing" setting under the Library menu. It predates the context menu and I haven't yet remembered to add it there.
Reply #154
New version out that includes the track preference selection and processing halting in the context menu. There are also some fixes.
Reply #155
You are top class! Thank you! Tested and it is now working "as it should". ;-)
(It is great, that the cursor is moving while the generation is turned off!)
Cannot edit tags of file, while waveform is generated
Reply #156
Well, there is another question/issue.
I often get the f2k Info
"Could not update tags (File is already in use) on:
C:\mp3\myfile.mp3"
when trying to change tags, while the waveform is still generated.
I change tags via scripts bound to keyboard shortcuts, so I usually change 2-3 tags very quickly, while the component is on its way to generate the waveform.
It happens on SSD, HD and Network too, no difference.  Keyboard-shortcuts are fast, waveform generation is not.
My options are,
a) halting the waveform generation
b) wait until the generation is finished, then press the shortcuts.
c) ?
I must say,
b) is out of question
a) will result in enjoying and using the waveform mainly when I do other work than tagging or moving files in f2k (which is only about 15% while the rest 85% is fetching/finetuning tags, etc.), so the fine waveform is mostly deactivated.
Which is a pitty IMHO, because it is so helpful to use (jumping visually, skipping parts) and very convenient (click=done) to work with.
c) Is something which did not come to my mind yet.... %-)
So the question is,
is there a way to omit this message (and of course enable editing/changing a file, while its beeing processed)?
The waveform generator opens the file in r/o mode (I guess), so why can't I edit that file?
Is this a Windows7 thing, or may this be canged in f2k somewhere, maybe any advanced setting?
Thanks for your ideas.
Reply #157
It's not a Windows 7 thing and you can't change that. foobar2000 wants exclusive write access to the file while tagging so an outside decoder having it open prevents this.
Only way that comes to mind to circumvent this is to read the file to memory and decode from there. But that would slow the waveform generation down and would consume a lot of memory. And wouldn't even work on large files.
Note that the faster your machine is the faster the waveform generation is. Typical tracks get scanned here in a fraction of a second so waiting for them to finish is not a problem. Also if you take advantage of the waveform cache and scan the files in advance there won't be any file locks later when showing the seekbar.
Since you like keyboard shortcuts you could map the '[main]' -> 'Library' -> 'Halt minibar processing' command to a key to be able to quickly turn it off if it gets in the way. And if you happen to use the 'playing track' mode hitting Stop will also stop incomplete waveform generation. It requires no further action, when you resume playback the waveform generation is restarted.
Reply #158
Actually should have asked Peter sooner. New version out now that allows you to tag files while waveform is being generated. And if your file is unseekable it will get tagged once waveform generation is finished.
Reply #159
sounds good, will test and report :-) Thank you!
Meanwhile...
sometimes, the wavebar generation aborts and there is no way to see/know,
-if the file is broken
-if the file just has a very long silent part at the end
-or if the generation just stopped, because of the slowness of my computer/network. (so everything is "normal")
I wonder if it will be usefull to have a (user-colorable) "vertical abortion bar" (see screenshot), which will indicate to the user: "hey, nothing wrong with the file, I just aborted the generation, because....".
What do you think?
I do a lot with visuals, so for me every indicator of a broken file is an alert to my eyes :-)
Reply #160
I don't like the idea of adding such feature to the component. It already has way too many configurable features for a supposedly simple minibar.
If the waveform generation stops because of too slow decoding speed there will be a note about it in the console.
Reply #161
Ah, I never noticed such a message  in the crowded console, will take a deeper look 8-) Thanks!
Reply #162
Hi, how can you lock the splitter between the WB and the playlist ? Thanks
Reply #163
I assume you use the Default UI. In layout editing mode right click on the splitter and you'll get 'Top pane' and 'Bottom pane' menu entries at the bottom. Select the appropriate submenu and click on 'Lock height' there. You need to be precise with the mouse to hit the splitter.
Reply #164
Perfect !
Reply #165
Hi there!
@Case, please consider the ability to add the feature "refresh wave" in the right-click menu. This is necessary when the wave is saved and the contents of the file have changed. To redraw the wave, I need to delete the entire base. Or I don’t know how to do it right.
Thank you!
Reply #166
^ There is an option in right-click track > Utilities > 'Regenerate minibar waveform'.
Reply #168
Hey all,
I have a problem: some tracks seem to share the same waveform. I already tried to re-index but with no luck. Any ideas?
Reply #169
Okay, found the issue. For my use case I had to change the matching pattern to %filename%
Reply #170
The default match string intentionally combines some tracks. I have my main library as FLAC and I keep a lossy version for portable use. I want them both to be able to use the same waveforms generated from the FLACs.
I wouldn't recommend using just %filename%. It can easily be the same for tracks from different albums. %path% would be safer, but not so good if you move files around often.
Reply #171
Don't forget %subsong% in the pattern, if you use multi-track formats.
Reply #172
Hello everyone,
I have recently migrated to Linux for a plethora of reasons (e.g Privacy to say the least), really foobar was one of the few things (especially this very plugin!) that was keeping me at bay (i.e. Windows) for a while. I'm now using Audacious (the closest thing so far). So I was wondering if anyone knows an alternative Waveform Seekbar for Linux.
Thanks & Cheers to @Case for developing awesome plugins...
Happy New Year.
Reply #173
@khashayar There exists a clone of my original foo_wave_seekbar for the Deadbeef music player: https://github.com/cboxdoerfer/ddb_waveform_seekbar
