Re: Waveform Minibar (mod)
Reply #15 –
The analysis is very crude.
It makes one pass across the audio data, splitting it into a few thousand sections. Each of those sections has min/max values and a rudimentary measure of energy computed.
While it could technically be possible to integrate a RG/R128 scan with the existing analysis pass, there's no point really. Just decode the files twice, once with the minibar and once with whatever RG scanners you have.
As for the waveform data itself and its min/max values, it's not exposed to any other components. I considered doing so with the `foo_wave_seekbar` component, but never really bothered. (Fun fact, it used to be two separate components, a database and an UI element.)
For the minibar and some hypothetical normalization component, that's up to Case to decide. I would just recommend using ReplayGain like the rest of us
