Topic: Transferring comments when encoding from OPUS (Read 966 times) previous topic - next topic
I want to transfer the comments field of an opus file to the converted one (usually mp3). How do i do this?
Re: Transferring comments when encoding from OPUS
Foobar2000 will transfer tags when converting files if set to do so in its converter options.  I assume you want to encode from one lossy format to another (will cause audio quality loss) due to device compatibility issues?
