Topic: CUERipper 2.1.6 frequent exceptions (Read 914 times) previous topic - next topic
I frequently get this exception when using CUERipper, usually near the end of the extraction.
If seem to be only related to display of some type of Winforms Progess Bar, so I guess when it happend, I don't need to worry about the result of the actual extraction?
Any solution/workaround?
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentException: Value must be greater than or equal to minimum.
   at ProgressODoom.AbstractProgressBar.set_Value(Int32 value)
   at CUERipper.frmCUERipper.<>c__DisplayClassb.<CDReadProgress>b__a()
   at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj)
   at System.Threading.ExecutionContext.runTryCode(Object userData)
   at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
   at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme)
   at System.Windows.Forms.Control.InvokeMarshaledCallbacks()
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.8922 (WinRelRS4.050727-8900)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
CUERipper
    Assembly Version: 1.9.0.0
    Win32 Version: 1.9.0.0
    CodeBase: file:///C:/Tools/CUETools_2.1.6/CUERipper.exe
CUETools.Processor
    Assembly Version: 2.1.6.0
    Win32 Version: 2.1.6.0
    CodeBase: file:///C:/Tools/CUETools_2.1.6/CUETools.Processor.DLL
CUETools.Codecs
    CodeBase: file:///C:/Tools/CUETools_2.1.6/CUETools.Codecs.DLL
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Deployment
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Deployment/2.0.0.0__b03f5f7f11d50a3a/System.Deployment.dll
System.Xml
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
CUETools.CTDB
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Tools/CUETools_2.1.6/CUETools.CTDB.DLL
CUETools.Compression
    CodeBase: file:///C:/Tools/CUETools_2.1.6/CUETools.Compression.DLL
CUETools.Ripper
    CodeBase: file:///C:/Tools/CUETools_2.1.6/CUETools.Ripper.DLL
CUETools.Codecs.APE
    Assembly Version: 1.0.5455.42426
    Win32 Version:
    CodeBase: file:///C:/Tools/CUETools_2.1.6/Plugins%20(x64)/CUETools.Codecs.APE.dll
System.Configuration
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
CUETools.Codecs.FLAC
    Assembly Version: 1.5.0.0
    Win32 Version:
    CodeBase: file:///C:/Tools/CUETools_2.1.6/Plugins%20(x64)/CUETools.Codecs.FLAC.dll
CUETools.Codecs.HDCD
    CodeBase: file:///C:/Tools/CUETools_2.1.6/Plugins%20(x64)/CUETools.Codecs.HDCD.dll
CUETools.Codecs.LAME
    CodeBase: file:///C:/Tools/CUETools_2.1.6/Plugins%20(x64)/CUETools.Codecs.LAME.dll
CUETools.Codecs.TTA
    Win32 Version:
    CodeBase: file:///C:/Tools/CUETools_2.1.6/Plugins%20(x64)/CUETools.Codecs.TTA.dll
CUETools.Codecs.WavPack
    Assembly Version: 1.2.0.0
    Win32 Version:
    CodeBase: file:///C:/Tools/CUETools_2.1.6/Plugins%20(x64)/CUETools.Codecs.WavPack.dll
CUETools.Compression.Rar
    CodeBase: file:///C:/Tools/CUETools_2.1.6/Plugins%20(x64)/CUETools.Compression.Rar.dll
Bwg.Hardware
    Assembly Version: 0.0.7.1
    Win32 Version: 0.0.7.1
    CodeBase: file:///C:/Tools/CUETools_2.1.6/plugins/Bwg.Hardware.DLL
Bwg.Logging
    CodeBase: file:///C:/Tools/CUETools_2.1.6/plugins/Bwg.Logging.DLL
Bwg.Scsi
    CodeBase: file:///C:/Tools/CUETools_2.1.6/plugins/Bwg.Scsi.DLL
CUETools.Codecs.ALAC
    CodeBase: file:///C:/Tools/CUETools_2.1.6/plugins/CUETools.Codecs.ALAC.DLL
CUETools.Codecs.FLACCL
    CodeBase: file:///C:/Tools/CUETools_2.1.6/plugins/CUETools.Codecs.FLACCL.DLL
CUETools.Codecs.FLAKE
    CodeBase: file:///C:/Tools/CUETools_2.1.6/plugins/CUETools.Codecs.FLAKE.DLL
CUETools.Codecs.WMA
    CodeBase: file:///C:/Tools/CUETools_2.1.6/plugins/CUETools.Codecs.WMA.DLL
CUETools.Compression.Zip
    CodeBase: file:///C:/Tools/CUETools_2.1.6/plugins/CUETools.Compression.Zip.DLL
CUETools.Ripper.SCSI
    CodeBase: file:///C:/Tools/CUETools_2.1.6/plugins/CUETools.Ripper.SCSI.DLL
CUETools.CDImage
    CodeBase: file:///C:/Tools/CUETools_2.1.6/CUETools.CDImage.DLL
ICSharpCode.SharpZipLib
    Assembly Version: 0.85.5.452
    Win32 Version: 0.85.5.452
    CodeBase: file:///C:/Tools/CUETools_2.1.6/plugins/ICSharpCode.SharpZipLib.DLL
OpenCLNet
    CodeBase: file:///C:/Tools/CUETools_2.1.6/plugins/OpenCLNet.DLL
WindowsMediaLib
    Assembly Version: 1.1.0.35988
    Win32 Version: 1.1.0.35988
    CodeBase: file:///C:/Tools/CUETools_2.1.6/plugins/WindowsMediaLib.DLL
radxhhcx
inlftpjw
msvcm90
    Assembly Version: 9.0.30729.9415
    Win32 Version: 9.00.30729.9415
    CodeBase: file:///C:/WINDOWS/WinSxS/amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.9415_none_08e0c10ba840a28a/msvcm90.dll
yvcwydnt
qsatuw-i
savjkwqc
ib0hi8zp
vjp3peus
ipcc682p
yc1qodba
7b37p6gu
_tr-7t7b
fxwru1rr
xaviboj_
dzt6xmh-
CUEControls
    CodeBase: file:///C:/Tools/CUETools_2.1.6/CUEControls.DLL
ProgressODoom
    Assembly Version: 1.0.5344.35988
    CodeBase: file:///C:/Tools/CUETools_2.1.6/ProgressODoom.DLL
pfw5ebfd
CUETools.AccurateRip
    CodeBase: file:///C:/Tools/CUETools_2.1.6/CUETools.AccurateRip.DLL
Freedb
    Assembly Version: 1.0.0.1
    Win32 Version: 1.0.0.1
    CodeBase: file:///C:/Tools/CUETools_2.1.6/Freedb.DLL
taglib-sharp
    Assembly Version: 2.0.4.0
    Win32 Version: 2.0.4.0
    CodeBase: file:///C:/Tools/CUETools_2.1.6/taglib-sharp.DLL
kvbm96z4
CUETools.Parity
    CodeBase: file:///C:/Tools/CUETools_2.1.6/CUETools.Parity.DLL
8j73nbvb
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Re: CUERipper 2.1.6 frequent exceptions
Thanks for reporting this.
You are probably right, shouldn't affect the results. The worst that can happen is the result would be truncated, but hopefully it is not. It's easy to verify the results with CUETools to make sure they are intact.
I'll look into this.
CUETools 2.1.6
I guess it's not truncating as it stops and closes the main window only after I discard the exception message.
Also, I downloaded the source code (2.1.6 I guess, I'm not used to GIT) and, in frmCUERipper.cs, replaced
progressBarErrors.Value = Math.Min(progressBarErrors.Maximum, (int)(100 * Math.Log(e.ErrorsCount / 10.0 + 1) / Math.Log((e.PassEnd - e.PassStart) / 10.0 + 1)));
with
progressBarErrors.Value = Math.Max(progressBarErrors.Minimum, Math.Min(progressBarErrors.Maximum, (int)(100 * Math.Log(e.ErrorsCount / 10.0 + 1) / Math.Log((e.PassEnd - e.PassStart) / 10.0 + 1))));
Because the problem was that the progess bar was receiving a value lower than zero.
So I now use my own fixed 2.1.6 version.
I didn't have time to analyse all the rest of the code so I hope my quick fix doesn't hide something important.
I re-ripped the possibly impacted CDs, just to be sure.
Thanks again!
CUETools 2.1.6
