Topic: Batchconvert to .mkv (Read 848 times) previous topic - next topic
can you recommend me a linux tool similar to mkvtoolnix-gui (script is also welcome), which allows lossless batchconversions to *.mkv while keeping the folderstructure intact?
unfortunately, with mkvtoolnix-gui, this does not seem to be possible.
Re: Batchconvert to .mkv
mkvtoolnix (without GUI) or ffmpeg (use `-c copy`).
You'll need to write a simple script to batch it, but it's easy. Maybe it's possible to take a shortcut by using it together with the find utility: https://en.wikipedia.org/wiki/Find_(Unix)
hello magicgoose,
thank you for your input. i am quite certain this is peanuts for skilled people (like you?) ;)
on the other hand, i would not have asked for a software recommendation, if i could write a script like this on my own, don't you think so?
i guess this script turns out to be a bit more complex than a short one-liner...
-search for video formats in one specific folder
-check for mkv support
-batchconvert all possible matches (mkvmerge) while retaining the folderstructure of the source path
-list all non processed files
would be interresting to know, if anyone has done something similar already?
meanwhile, i got this (very) basic command that batchconverts to *.mkv: for file in *.mp4; do mkvmerge $file -o $file.mkv; done
actually, it does not work for filenames containing 'white spaces' though. i tried to modify but it fails.
can you help me improving it, so it will accept unix nonconform filename conventions, as well?
thank you!
for file in *.mp4; do mkvmerge "$file" -o "$file.mkv"; done
Maybe? Sorry realised it's not Windows but pretty sure you need to do it in bash as well.
works like charm, thank you so much.
in fact, i already tried this exact command, but used ' instead of ". not sure why it worked before?
