Batchconvert to .mkv 2018-05-01 20:16:07 can you recommend me a linux tool similar to mkvtoolnix-gui (script is also welcome), which allows lossless batchconversions to *.mkv while keeping the folderstructure intact?unfortunately, with mkvtoolnix-gui, this does not seem to be possible.
Re: Batchconvert to .mkv Reply #1 – 2018-05-01 21:32:46 mkvtoolnix (without GUI) or ffmpeg (use `-c copy`).You'll need to write a simple script to batch it, but it's easy. Maybe it's possible to take a shortcut by using it together with the find utility: https://en.wikipedia.org/wiki/Find_(Unix)
Re: Batchconvert to .mkv Reply #2 – 2018-05-02 06:32:21 Quote from: magicgoose on 2018-05-01 21:32:46You'll need to write a simple script to batch it, but it's easy.hello magicgoose,thank you for your input. i am quite certain this is peanuts for skilled people (like you?) on the other hand, i would not have asked for a software recommendation, if i could write a script like this on my own, don't you think so?i guess this script turns out to be a bit more complex than a short one-liner...-search for video formats in one specific folder-check for mkv support-batchconvert all possible matches (mkvmerge) while retaining the folderstructure of the source path-list all non processed fileswould be interresting to know, if anyone has done something similar already? Last Edit: 2018-05-02 06:34:33 by sanskrit44
Re: Batchconvert to .mkv Reply #3 – 2018-05-04 11:46:44 meanwhile, i got this (very) basic command that batchconverts to *.mkv: for file in *.mp4; do mkvmerge $file -o $file.mkv; doneactually, it does not work for filenames containing 'white spaces' though. i tried to modify but it fails.can you help me improving it, so it will accept unix nonconform filename conventions, as well?thank you!
Re: Batchconvert to .mkv Reply #4 – 2018-05-04 15:37:13 for file in *.mp4; do mkvmerge "$file" -o "$file.mkv"; doneMaybe? Sorry realised it's not Windows but pretty sure you need to do it in bash as well.
Re: Batchconvert to .mkv Reply #5 – 2018-05-04 18:06:22 works like charm, thank you so much.in fact, i already tried this exact command, but used ' instead of ". not sure why it worked before?
