Re: Audio Summing Algorithm
Reply #25 –
If I get up the energy to play with this stuff, I can probably put together a rough 'FFT' based summer (that is, not an FFT, but power based) to see what forcing the phases to match would sound like. I suspect the results would at least be grainy sounding (like some of the ABBA recordings due to the abuse of the quadrature/destroying the analytical nature of the signal), but more than likely renders the sound unintelligible.
Actually, I have done something similar before -- by zeroing the phase of a given FFT (magnitudes the same, phase is zeroed -- all the same), and the result was pretty much unintelligble-- it was possible to detect some of the material, but didn't seem to be useful.
Can you send us some samples, please? And why does it happen?
