Topic: Why are some tracks sorted alphabetically? (Read 660 times) previous topic - next topic
I've searched but can't find much info that mentions this exact problem, so hopefully someone can shed some light on it for me.
Occasionally an album will show up in my playlist showing tracks sorted alphabetically rather than by track number. I've tried adjusting 'sort incoming' in shell integration and sort format under the playlist settings but nothing changes with the affected album(s). Am i right in thinking that if my sort order was off, that would affect all albums anyway rather than just a handful?
I've tried removing and redoing tags using mp3tag but again, no joy.
I'm using Tedgo's DarkOne V4 Mod by the way.
If there's any info i've left out that could help please let me know, any help will be much appreciated.
Re: Why are some tracks sorted alphabetically?
Looks like i may have found the solution.
All i needed to do was sort by track number in the context menu (which sorts everything by track number) then re-sort by default.
Thought i'd post in the hope this can help someone.
Jamie
I don't know how you add tracks to playlist, so I cannot recommend any changes in the settings, but you may just rename these files so their filenames start with track number. For example: "Echoes.mp3" -> "06 - Echoes.mp3".
