Topic: Not updating tags (Read 784 times) previous topic - next topic
Not updating tags
Hello all,
I have been using foobar and mp3tag for the past 4 years with no problem.
Can't tell when foobar statred not to update tags such as genre, release type.
Every tag seems correct when i look upon with mp3 tag but when it comes to foobar it seems there's no change in tags.
(please see attached images)
I have tried everything (deleted library, deleted index, did full rescan several times)
So far  the only workaround is to change tags within foobar, then it displays everything correctly.
Does anyone have any ideas what could be the problem?
Thanks in advanced,
Re: Not updating tags
try hold Shift + Right Click on song(s), Tagging -> Reload info from file(s)
Thank you, that does the trick.
But while ago every track was updating itself automatically on the fly,
Maybe you checked "Preserve file modification date" option in MP3Tag?
Sorry for not mentioning earlier but;
Foobar updates all the tags as it is tagged with mp3tag on the fly as soon as i change folder's name on windows explorer.
(images attached)
My bad, i can't seem to find that "Preserve file modification date" option on mp3tag  ::)
Thank you so much!! Just found that box and unchecked!
Now it works, you made my day  (literally past few days)
