Topic: Vorbis 1.3.7 aoTuV and Lancer patches (Read 46120 times) previous topic - next topic
Re: Vorbis 1.3.7 aoTuV and Lancer patches
Reply #50
Hi @enzo! In updating the AUR package to v1.3.7, I am getting a segfault during `make check` for test 4:
Making check in m4
make[1]: Entering directory '/build/libvorbis-aotuv-lancer/src/libvorbis-1.3.7/m4'
make[1]: Nothing to be done for 'check'.
make[1]: Leaving directory '/build/libvorbis-aotuv-lancer/src/libvorbis-1.3.7/m4'
Making check in include
make[1]: Entering directory '/build/libvorbis-aotuv-lancer/src/libvorbis-1.3.7/include'
Making check in vorbis
make[2]: Entering directory '/build/libvorbis-aotuv-lancer/src/libvorbis-1.3.7/include/vorbis'
make[2]: Nothing to be done for 'check'.
make[2]: Leaving directory '/build/libvorbis-aotuv-lancer/src/libvorbis-1.3.7/include/vorbis'
make[2]: Entering directory '/build/libvorbis-aotuv-lancer/src/libvorbis-1.3.7/include'
make[2]: Nothing to be done for 'check-am'.
make[2]: Leaving directory '/build/libvorbis-aotuv-lancer/src/libvorbis-1.3.7/include'
make[1]: Leaving directory '/build/libvorbis-aotuv-lancer/src/libvorbis-1.3.7/include'
Making check in vq
make[1]: Entering directory '/build/libvorbis-aotuv-lancer/src/libvorbis-1.3.7/vq'
make[1]: Leaving directory '/build/libvorbis-aotuv-lancer/src/libvorbis-1.3.7/vq'
Making check in lib
make[1]: Entering directory '/build/libvorbis-aotuv-lancer/src/libvorbis-1.3.7/lib'
Making check in modes
make[2]: Entering directory '/build/libvorbis-aotuv-lancer/src/libvorbis-1.3.7/lib/modes'
make[2]: Leaving directory '/build/libvorbis-aotuv-lancer/src/libvorbis-1.3.7/lib/modes'
Making check in books
make[2]: Entering directory '/build/libvorbis-aotuv-lancer/src/libvorbis-1.3.7/lib/books'
Making check in coupled
make[3]: Entering directory '/build/libvorbis-aotuv-lancer/src/libvorbis-1.3.7/lib/books/coupled'
make[3]: Nothing to be done for 'check'.
make[3]: Leaving directory '/build/libvorbis-aotuv-lancer/src/libvorbis-1.3.7/lib/books/coupled'
Making check in uncoupled
make[3]: Entering directory '/build/libvorbis-aotuv-lancer/src/libvorbis-1.3.7/lib/books/uncoupled'
make[3]: Leaving directory '/build/libvorbis-aotuv-lancer/src/libvorbis-1.3.7/lib/books/uncoupled'
Making check in floor
make[3]: Entering directory '/build/libvorbis-aotuv-lancer/src/libvorbis-1.3.7/lib/books/floor'
make[3]: Leaving directory '/build/libvorbis-aotuv-lancer/src/libvorbis-1.3.7/lib/books/floor'
make[3]: Entering directory '/build/libvorbis-aotuv-lancer/src/libvorbis-1.3.7/lib/books'
make[3]: Nothing to be done for 'check-am'.
make[3]: Leaving directory '/build/libvorbis-aotuv-lancer/src/libvorbis-1.3.7/lib/books'
make[2]: Leaving directory '/build/libvorbis-aotuv-lancer/src/libvorbis-1.3.7/lib/books'
make[2]: Entering directory '/build/libvorbis-aotuv-lancer/src/libvorbis-1.3.7/lib'
make[2]: Leaving directory '/build/libvorbis-aotuv-lancer/src/libvorbis-1.3.7/lib'
./test_sharedbook
Dequant test 1... OK
Dequant test 2... OK
Dequant test 3... OK
Dequant test 4... make[1]: *** [Makefile:1033: check] Segmentation fault (core dumped)
make[1]: Leaving directory '/build/libvorbis-aotuv-lancer/src/libvorbis-1.3.7/lib'
make: *** [Makefile:530: check-recursive] Error 1
==> ERROR:(B A failure occurred in check().(B
    Aborting...(B
I am using the following PKGBUILD:
pkgname=libvorbis-aotuv-lancer
pkgver=1.3.7
_srcname="libvorbis-${pkgver}"
pkgrel=1
_aotuv_ver=b6.03
pkgdesc='A fork of libvorbis intended to provide better quality sound at low to medium bitrates, with lancer patches to improve performance'
arch=('i686' 'x86_64')
url='https://hydrogenaud.io/index.php?topic=115774.0'
license=('BSD')
depends=('libogg.so')
conflicts=('libvorbis' 'libvorbis-aotuv')
provides=(
  'libvorbis.so'
  'libvorbisenc.so'
  'libvorbisfile.so'
source=("http://downloads.xiph.org/releases/vorbis/${_srcname}.tar.gz"
        "https://freac.org/patches/${_srcname}-aotuv-${_aotuv_ver}.patch"
        "https://freac.org/patches/${_srcname}-aotuv-${_aotuv_ver}-lancer.patch")
sha256sums=('0e982409a9c3fc82ee06e08205b1355e5c6aa4c36bca58146ef399621b0ce5ab'
            '21c9801f70fa254bb2019266ae51cdabf9b9bbf089fe91275db8722a0cfc46b6'
            'db4a6698913c4e05d43cfbbd174b1deb3747f7283a8618d8e009425d93a23769')
prepare() {
cd "${_srcname}"
# apply aotuv patches
patch -p1 -i "${srcdir}/${_srcname}-aotuv-${_aotuv_ver}.patch"
# apply lancer patches
patch -p1 -i "${srcdir}/${_srcname}-aotuv-${_aotuv_ver}-lancer.patch"
build() {
cd "${_srcname}"
./configure \
    --prefix=/usr \
    --disable-static \
    --enable-shared
    make
check() {
cd "${_srcname}"
make -k check
package() {
cd "${_srcname}"
make DESTDIR="${pkgdir}/" install
install -Dm644 COPYING "${pkgdir}/usr/share/licenses/${pkgname}/LICENSE"
The build log looks normal (external link because otherwise post exceeds character limit).
There are no issues with building the current 1.3.6 version or standard libvorbis 1.3.7 (without patches) using the same method (building in a clean chroot), however the exact same issue happens when I do a standard build from your repo's master branch.
Any idea of what might be at play here?
edit: I got something slightly better using the previously used `make -j1 check` (as it is in the current 1.3.6 PKBGUILD):
Making check in m4
Making check in vq
Making check in lib
./test_sharedbook
Making check in test
make[1]: Entering directory '/build/libvorbis-aotuv-lancer/src/libvorbis-1.3.7/test'
make  test
  CC       util.o
  CC       write_read.o
make[2]: Entering directory '/build/libvorbis-aotuv-lancer/src/libvorbis-1.3.7/test'
  CC       test.o
  CC       util.o
  CC       write_read.o
  CC       test.o
mv: cannot move '.deps/write_read.Tpo' to '.deps/write_read.Po': No such file or directory
make[1]: *** [Makefile:385: write_read.o] Error 1
  CCLD     test
make[2]: Leaving directory '/build/libvorbis-aotuv-lancer/src/libvorbis-1.3.7/test'
make[1]: Target 'check' not remade because of errors.
make[1]: Leaving directory '/build/libvorbis-aotuv-lancer/src/libvorbis-1.3.7/test'
Making check in doc
make[1]: Entering directory '/build/libvorbis-aotuv-lancer/src/libvorbis-1.3.7/doc'
Making check in libvorbis
make[2]: Entering directory '/build/libvorbis-aotuv-lancer/src/libvorbis-1.3.7/doc/libvorbis'
make[2]: Leaving directory '/build/libvorbis-aotuv-lancer/src/libvorbis-1.3.7/doc/libvorbis'
Making check in vorbisfile
make[2]: Entering directory '/build/libvorbis-aotuv-lancer/src/libvorbis-1.3.7/doc/vorbisfile'
make[2]: Leaving directory '/build/libvorbis-aotuv-lancer/src/libvorbis-1.3.7/doc/vorbisfile'
Making check in vorbisenc
make[2]: Entering directory '/build/libvorbis-aotuv-lancer/src/libvorbis-1.3.7/doc/vorbisenc'
make[2]: Leaving directory '/build/libvorbis-aotuv-lancer/src/libvorbis-1.3.7/doc/vorbisenc'
make[2]: Entering directory '/build/libvorbis-aotuv-lancer/src/libvorbis-1.3.7/doc'
make[2]: Leaving directory '/build/libvorbis-aotuv-lancer/src/libvorbis-1.3.7/doc'
make[1]: Leaving directory '/build/libvorbis-aotuv-lancer/src/libvorbis-1.3.7/doc'
make[1]: Entering directory '/build/libvorbis-aotuv-lancer/src/libvorbis-1.3.7'
make[1]: Leaving directory '/build/libvorbis-aotuv-lancer/src/libvorbis-1.3.7'
make: Target 'check' not remade because of errors.
    Aborting...(B
Reply #51
I got slightly further by adding an `./autogen.sh` step in the `prepare()` stage, although that should not (and was not) needed while building from a tarball?
Making check in m4
Making check in vq
Making check in lib
./test_sharedbook
make  test
  CC       write_read.o
  CC       test.o
  CC       util.o
  CC       write_read.o
  CC       util.o
  CC       test.o
  CCLD     test
  CCLD     test
./test
Testing 1 channel
<all channel tests ok up to...>
    vorbis_8ch_q9.5_96000.ogg : ok
Making check in doc
make: *** [Makefile:532: check-recursive] Error 1
    Aborting...(B
The current PKGBUILD as it stands:
pkgver=1.3.7
pkgrel=1
_aotuv_ver=b6.03
license=('BSD')
provides=(
  'libvorbis.so'
  'libvorbisenc.so'
  'libvorbisfile.so'
prepare() {
cd "${_srcname}"
./autogen.sh
build() {
cd "${_srcname}"
./configure \
    --prefix=/usr \
    --disable-static \
    --enable-shared
    make
check() {
cd "${_srcname}"
make -k check
package() {
cd "${_srcname}"
PS: I noticed there was no 1.3.7 release/tag on your Github repo, was it intentional?
edit: extract from systemd journal if that may help:
févr. 20 03:48:23 kernel: test_sharedbook[68595]: segfault at 556bb0000000 ip 00007ff21fb84c9e sp 00007ffea83e76b0 error 4 in libc-2.33.so[7ff21fb1f000+14c000]
févr. 20 03:48:23 kernel: Code: a8 02 75 40 48 8b 15 d1 50 13 00 64 48 83 3a 00 0f 84 9e 00 00 00 48 8d 3d 6f 5d 13 00 a8 04 74 0c 48 89 f0 48 25 00 00 00 fc <48> 8b 38 31 d2 e8 08 c0 ff ff 64 89 2b 48 83 c4 18 5b 5d c3 66 0f
févr. 20 03:48:23 systemd[1]: Started Process Core Dump (PID 68596/UID 0).
févr. 20 03:48:23 systemd-coredump[68597]: Resource limits disable core dumping for process 68595 (test_sharedbook).
févr. 20 03:48:23 systemd-coredump[68597]: [🡕] Process 68595 (test_sharedbook) of user 1000 dumped core.
Some more lines appeared when building outside of the chroot:
Stack trace of thread 91257:
#0  0x00007f6b478c5cde __libc_free (libc.so.6 + 0x8bcde)
#1  0x0000559ea490a0e3 n/a (<buildpath>/libvorbis-aotuv-lancer/src/libvorbis-1.3.7/lib/test_sharedbook + 0x10e3)
Reply #52
Thank you for bringing this up, @Isayama!
Just investigated this and found that it's a bug in the test itself, i.e. not in the library / the patches. In the test code in sharedbook.c there's a mismatched alloc and free which causes the error. The call to free in line 584 of sharedbook.c needs to be changed to _ogg_free to fix this.
I applied the fix in the enzo1982/vorbis-aotuv-lancer repository and also opened a pull request for the official xiph/libvorbis code.
I won't update the patch for this. You can either apply a custom patch or sed call in the prepare section of the packaging script or directly refer to the 6df96d98 commit from enzo1982/vorbis-aotuv-lancer instead of the original package and patch files.
Reply #53
Custom patch is probably the best way to apply a post-release fix to an AUR or even non-AUR package, and bump the pkgrel.
Reply #54
Thank you very much @enzo for looking into this so quickly and upstreaming it. I can confirm the build completes successfully after applying your patch.
Regarding this specific AUR package, I would be in favor of directly using your repo as its source since this package pertains to "A fork of libvorbis intended to provide better quality sound at low to medium bitrates, with lancer patches to improve performance", however as a non-development package it would require a 1.3.7 release to be made/tagged (no need to differ from upstream) to use it as a base and then apply the patch on top.
(Arch also has VCS packages, but to make proper use of it I'd need to request a package name change to *-git, although in the long run that might be a better idea...)
That's definitely nitpicking, but can you tag/make a release for 1.3.7 in enzo1982/vorbis-aotuv-lancer?
In any case thanks a lot for responding quickly to this.
Reply #55
Just pushed the v1.3.7 tag. Simply forgot to do that when I updated the repository for that version.
However, thinking about it, it might not be such a good idea to base the package on my repository after all. I'll likely do a force push when integrating a future libvorbis 1.3.8. This means the three commits after the 1.3.7 tag will go away and be replaced with new commits. Using patch files on top of the 1.3.7 tag will be fine, but don't reference the commit hashes directly.
Reply #56
Thanks! Well, if it gives you more leeway like that, I've used the upstream tarball and applied your patches on top. As an added bonus it allows to verify the integrity of the sources with the provided signature. We'll see down the road with 1.3.8 how we change it :)
Cheers
